  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aww man, if farking JAP
okay first plan of action
check with whom ever it was who turned it into a clock concealed timer cos he has obviously managed to install it with jap instruction.
second, why are these boost gauges dead
ecu is not in the boot
its in the passenger kick panel
under the glove box and to your left, just under the factory flare in that panel
it comes off quite simply and then the ecu sits there.
i dont see why the gauges both died at the same time, because if the dash one is electronic then yeah maybe a wire problem, but if the blitz one is dead thats weird cos its a mechanical gauge.
the vacuum line is all that is involved in making it move.
which means the car is not providing a reading to the vacuum line, which means the line must not be connected.
i dont get any other explanation
I think the vacuum hose blew off the back of the gauge,
that would make more sense.
Especially if both the gauges died
i just dont get it hey
if its not resolved by the weekend. i will come round if thats cool. and maybe we can go through the wires and the lines.
yeah riaz, good idea - my dad was getting worried didnt know wat else was going 2 **** up but i told him it was alright and i would get it fix.
And today i notic the chick factory to the skyline. after work my mates rock up with some girls that work at macca's and one ask me to take her home and smile at me like she wanna 2 hook up this was wired cuz she never talk 2 me at work at all.
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
