  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Twin PT52 Precision Turbo Engine Turbos will provide the Boost. Each Turbo is capable of making 600HP or 1000CFM of Air. Together the combination is good for at least 1200HP and/or 2000CFM of Air. The Turbos were selected to have a small nozzle diameter as well as a .85 AR Ratio. To allow these Turbos to spool up quickly in order to reduce the sensation of Turbo Lag.
:drooling:
mike if you read this before you go.
there is an arcade on murray street if you are walking down from pier street carpark
go past baskin and robbins
and then there is an asian grocery store
go past that and then next to it is an arcade. there is a shop in there called Aspec
go talk to franky and he will get you all the globes etc you need, he knows what goes in etc
no worries Mr Riceroni
peace
nah - soarer turbos use the same engines as the chasers. though with less beefy cams I think.
the old 1jz. little brother to the 2jz.
later model soarers came in a 2.5L tt, 3L6 n/a and the 4L v8s. now theyre purely v8s I think. but I have seen a twin turboed version of the new one in a video of some tuning shop in japland. forget which one....
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
