  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Riaz- just make it over 220HP at wheels.and ur project will be sweet
Yeah Riaz 220 at the wheels should give you a pretty sweet power to weight and gives some of us Skylines owners more than a bit of a shcok from the lights!!!
ok all the fustration is out now *clam blue ocean* on with the report that doesnt end .... yes it goes on n on my friend .... some stupid blonde bitch started typing it not knowing what it was .... but wait until she's typing it forever just because .....
Mike your odometer not working isnt something I know how to fix etc. it just proves the theory that no KM's are to be trusted on a jap car, which is what i told you anyways. and now the frgging thing stops working, its all too dodge.
maybe the previous owners C-red might be able to help fix it.
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
