The best setup for a turbo car is for virtually no restriction. The exhaust wheel will spin more freely the less exhaust backpressure there is. A 3.5" system sounds good, and removal of centre mufflers and cat will also work well, the less restriction the better.
See'ya:burnout:
JiMiH,
With a factory turbo on a samll capacity engine then there is almost no benefit to going too big, I'd say that a 4" dump is more than enough.
sidewaymambo,
The best in terms of power is a dump with nothing after it, but this is too loud and the cops will pull you over straight away. A large dump with separate wastegate pipe followed by no cat or cetre muffler and with a muffler at the very end is the best street setup. Be warned however that this is still very loud and no cat is illegal.
See'ya:burnout:
I can testify to my brothers 180SX which runs an apexi N1, fat dump pipe and no cat. Goes like s.hit of a shiny shovel, but the drawbacks are A: no cat's are highly illegal and B: the noise shakes your car port apart when you come home and leave the turbo timer on.
GTSt V-Spec: you know anyone in perth who does good dump pipes?
There are plenty of people who can do a good exhaust dump but I tend to use Genie exhausts in Myaree, they are very good as the do all of the Xspeed work and are now very good at doing custom work for Jap cars.
See'ya:burnout:
I have an R33 with stock turbo + Nismo 3" Cat-back exhaust.
Can someone -please- give me an exact URL of exactly what front section of my exhaust i need to replace the standard section ?
I have absolutely no idea what i need, where to get it done and how much it'll cost but i -do- want to get it done very soon.
benm,
If you go to any exhaust place and ask for a custom turbo dump pipe with separate internal wastegate pipe to connect to your 3" system then they should have no problems. Expect to pay anywhere from $250-$350 for a custom job, you can always buy a Jap dump but they are usually more expensive.
See'ya:burnout:
GODF4Th3R,
Doing everything it alway the best, the dump is very important, but if your strangling it with the front pipe and cat then it's not going to do too much. The exhaust will only flow as well as the most restrictive bit.
Hi-flow cat's are the go, will add a little bit extra power at standard boost, but will make more difference as you increase the power.
See'ya:burnout:
Your dead right, heat is our enemy. By increasing the airflow then the heat is removed via the exhasut system, with a restriction in the exhasut then it causes excessive heating of the turbo exhaust housing and this leads to the car pinging as it pre-heats the air.
See'ya:burnout:
I got XSpeed to get me the whole lot (dump, front pipe and 3" hi flo) They get theirs done at Genie Myaree as GTSt VSpec mentioned earlier. It cost me just under $800.
Apparently, it used to be cheaper as they used different cat(ceramic?), but they tended to break apart. Mine was one of the newer designs. It cost a little more, but I haven't had any problems so far.
Another question; isn't is true that the further from the turbo the restriction (eg the rear silencer) the less effect on back pressure and HP? So if you do the dump and front pipe in a decent size (say 4") then run a high flow cat and legal 3" cat back it should be better than running say a stock dump and front pipe with a 3.5" cat back?
G0DF4Th3R,
Kichigai is right, you can get a complete system from Genie pretty cheap these days, but if you want a name brand muffler like APexi/Trust etc then they cost about $500 by themselves.
Ronin 09,
Yes your right, what happens is that a wave of backpressure, like sound waves, oscillates between the ends of the exhaust system, the further the restrtictions are away the less effect this has on the backpressure and ultimately HP, also the reason tuned length exhaust manifold are better.
See'ya:burnout:
Oh man i wish i could find a workshop that actually knew what they were on about.
Midas had no idea and told me to come back next tuesday when their "exhaust specialist" would be in and Muffler man just told me to go and see a turbo shop.
ARGH maybe i should just walk in somewhere with a $50 note glued to my head so that they realise im serious.
Benm, search the threads for 'exhaust' and see if there are any recommended in Perth. I would get a custom dump and front pipe made for your car instead of getting the Nismo one, as it will be heaps cheaper and do as good a job. Because your Nismo cat back is already pretty quiet, the addition of the dump and front pipe shouldn't add too much dB.
Or you could get a premade dump and front pipe from somewhere like Japanese Motorsport, they have stainless dump pipes for 350 and stainless front pipes for 350. Just make sure they will bolt up to the cat converter in the factory position (assuming you have the stock cat)
-cheers m
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
