Greensborough/Mill Park/Heidelburgers
  • Replies 115
haha it was me! Hello :O
I think we may have seen you coming back to your car but we buggered off when we saw the cops arriving... (there was a stolen falcon dumped next to your car and still running!).
Anyway 46n2 was a bit jealous of your rear wang (its bigger than his) hehe :)
Are you from the area?
~Kaz & Michael
haha it was me! Hello :P
Anyway 46n2 was a bit jealous of your rear wang (its bigger than his) hehe :P
~Kaz & Michael
Hey Kaz and Michael! LMFAO that was BRILLIANT, we loved it! We also took off when we saw the cops there - that car was right next to ours and we thought they were checking out the Rex!!! We were wondering if I'd taken my silver WRX as well, if you'd have left two notes as we both have big rear wangs. :D:) He he he!
I am from Eltham and Matt's from out Vermont way. We went to see a movie. Thanks for the note, we thought it was great! Hope to see you again in the near future.
Jenna and Matt
Edited by Tiiger
Might as well make something useful out of this thread and take this opportunity to try and revive the old 1st Sunday of the Month Northies meet for breakfast/coffee at the promenade in South Morang.
Used to be just a locals thing, meet up for coffee by the "lake". Don't have to bring your line (most of us don't because they're somehow broken or being mended, and the eggs and bacon breakfast is to die for. Used to be a regular meetup, but has since died off, so maybe if people are up for it might bring it back.
The next first sunday is this sunday (which coincides with the Show and Shine, so if you guys want to meet and then cruise to the S&S, otherwise make it Sunday afterwards)
For half the guys that come (at about 11am if you're de-toxxing) its an early lunch. Its in south morang, up plenty road, past Mill Park. Whereis Linkage
I'm in Bundoora (near La Trobe Uni/Macca's on Plenty).
oooooo ..... im from Eltham
:cheers:
-Ruffels
......... OH... AND.... theres a white 33 with the same kit as me and a very similar number plate to mine.. all my friends mistake him for me... the numebr plate is RUTTLZ... is this person on the site?
Edited by Ruffels
my gf lives up in greenzy and im up there a fair bit, why dont u guys make it later or like a evening supper, with cakes n stuff instead of late breaky, hmmm the thought of getting up early is unsettling to some of us :)
hey,
im from greensy too, at simpson barracks.. geof, south morang pub goes off of a friday night :) anyway, would be good to catch up with some of ya, theres a few skylines on base i could try and drag along (about 5 of them plus mine haha),
mark
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
