eheh not quite, he doesnt even have 1 to lose yet...only on his l's
dang, i had a bluebird on my P's let alone a 33 on my L's!!!! Very noice, at least u can get some practice behind the wheel of the 33 while u have someone with experience watching ya/teaching ya.
  • Replies 169
Posted Images
haha yeah thats how i see it too
im not the only one on here that has/had a skyline on thier L's
just off the top of my head foznice has an r32 gtst, hes on his L's too :D
when i first joined up to the site i got flamed for it hahah (that was 6 months ago)
and my parents were even called irresponsible by some members :D
not that it was anything to do with ym parents.. after all it was my hard earn cash lol
better then those people who get thier p's and jump straight in one without any previous experience in it.. anywho this isnt thread about l platers :) lol so i'll continue on
anyone else got some pics of the day? mine all turned out pretty crap :(
-Ruffels
Yeah - we all went and got the 'generic Skyline owner' dressup kit before the event too :)
Saw your bus in HPI - nice :D
My bus? I guess I should go and get it then. 3 magazines in 1 month! Haha.
You know you can invite the mags to your events. They don't always show up though :D.
Nah RUFFELS, to me its way better to learn in a line on ur L's than on ur P's, as i said someone with experience there to watch. I remember driving my ol mans 13sec torana, had power steering only Arnie could tame, i must admit i learned alot in that car, but only cos my ol man was sittin next to me teachin. If he wasnt i know id probably would have hurt myself or others.
i have mentioned it. many times....why do you say that?
Yeah I was just kidding mate, seem to read that comment in every single thread in the vic section! lol
You can buy my GTS if you really want tho! :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
