So....what is wrong with my RB26?
Recently rebuilt by a engine builder with very suspect abilities. Completed 2000klm since rebuild including 4 oil changes. Running standard computer and standard boost. Rev limit is 8500.
Last 1000klm since running in finished have been a practice day at Wakefiled Park, a race meet at Oran Park and a race meet at Wakefield. In the last race at wakefeild I heard a knock on the last lap, finished the cool down lap and parked it.
The problem - there is a knock/tap in the motor. rises with revs
Oil pressure is normal (great)
Compression test results:
# - Dry test - wet test
1 - 10.5 kg/cm2 - 12.5 kg/cm2
2 - 12 kg/cm2 - 14 kg/cm2
3 - 12 kg/cm2 - 14 kg/cm2
4 - 12 kg/cm2 - 14 kg/cm2
5 - 12 kg/cm2 - 14 kg/cm2
6 - 11.5 kg/cm2 - 13.5 kg/cm2
Battery was boosted by a running car, engine was dead cold. No leakdown test
The noise sounds like it is coming from the top of the motor, maybe at the front or maybe I am imagining it. I put a screwdriver on the head next to my ear, and looked like a person with a screwdriver in my ear.
Anyway....lets have some educated guesses about what is wrong...answers to come sometime in the next few weeks when I get around to pulling it out.
https://www.sau.com.au/forums/topic/89720-what-is-wrong-with-my-rb26/
  • Replies 59
Duncan ,
It doesn't sound good mate , at a guess ( wild one at that ) i would say its a big and bearing , usualy one at the rear ( number 6 ) but you have a built engine so who knows if they checked clearances or not when they assembled it .
Compression on number one is very suss for a built engine as well as number 6 .
when you say wet test ai would assume you mean you put oil in the cil and heaps of it by the look of the resaults .
The comp test shoul be done on a warm engine and the throttle fully open .
Do a leakdown test it will give you a bit more info ( more reliable ) .
Does the knock get louder as it warms up ? Is it there when you first start it cold ?It could be a lifter or even an injector but my money is on a big end , but i hope i'm wrong .
yeah I wasn't shy with the oil....
Will actually get hold of a leak down tester at some stage but it wont help decide if I have a head or ring problem will it?
The knock is there from cold, not noticably noisier when warm. But I didn't run it up to temp today I dont want to do any further damage.
Bearing clearances were checked at the rebuild and they suggested standard size bearings which i was a bit surprised about I thought an older crank that had been machined might need oversize bearings. Unfortunately I didn't measure the clearances myself :)
Injector is interesting....when can an injector get noisey? I might throw another one in and see if there is any difference to the noise.
What can fail in a lifter? got any pics to edumacate me?
I have a leakdown tester but you will need a compressor to do the test , i can do for you if you like and i maybe able to give you a more educated guess as to whats wrong with it .
If its a bearing you will do more damage to the crank by running it but if you pulle it out you should change the crank with a new one anyway , if you spin the bearing then conrod through the block is possible .
If the crank was machined they would have used undersize bearings .
Injector can be noisy warm or cold .
A lifter can be come noisy when the clearances grow , there nothing wrong with the lifter , just bigger clearance . you can check with a filler gauge but you need to take the rocker covers off .
The lower comp on the 2 cil maybe because they had the valve clearances to tight ( to have a quiet engine ) and the valves are starting to burn a little .
Did you check comp before ?
You are correct in saying a leakdown test wont tell you if it leaks for valves or rings but it will still tell you more than a comp test .
To much oil in the cil thats the reason comp went up so much ( you made the combustion chamber smaller ( like having higher comp ratio ) .
Edited by wrxhoon
Did you check for woodpeckers inside before u put the block back together? Hope it's not anything serious :)
BTW this was funny....but I didn't post it.....SAU stuffing up or have I been ha><0r3d?
Duncan ,
I just thought of another possibility , just make things abit more complex , could be a gudgeon pin as well , depending on what they used , pistons and circlips or spirolocks , one of them may have come off !!! Then the knock you hear could be the gudgeon pin hiting the bore , you said it sounds like coming from the front didnt you ? That will explain the lower comp on number one as well , the circlip could have scored the bore .
Hard to say without hearing it and knowing how / what they used in the build .
i can say with certainty that it's not a big end bearing... i would definately look into the woodpecker idea though. they can make a noise quite similar to bearing knock as their beaks aren't compatible with the cast iron RB block...
also, could be tinitis from standing around Niels race car or other hearing damage caused be the screwdriver in your ear (you did put the handle in you ear right?) or a combination of the two problems. and actually you have no problem at all. except for the permenantly damaged hearing which is preferable to another RB26 rebuild...
feel better duncan?
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
