  • Replies 183
Posted Images
Cartoys have recently acquired a red R33GTR - not sure if it is the rare red or not (haven't seen it yet). Either way I haven't seen a red R33GTR before!
car toys 33gtr isnt as red but very nice still, mate works there, getting new e manage unltimate soon as arrives in store. Very nice cars here, still gotta fix mine up, if a cruise is organised id like to know about it.
Anyway my car, dont know if was dirty as in shade but cant keep black clean for too long anywayz. Hey deluxe if you see me at my mates place come say hi.
black33_26 - can i have your rims?  :O nice clean series 2 you got there.
Hey nozila they are only 17" volks, im looking to get some new ones later on, bought them with the car, the old owner must have driven into a few gutters im guessing with the damage to the rims. Yeah has had a tow bar dent since pic and some wanker rubbed the whole right side of the bumper with his CAR!!!!
i dunno if u guys find this as well, but there are a lot of people that arent on these forums that seem to just stare me down in my car.
do others find this?
hey, yeah i get that somtimes in my car...like especially old ppl, they think ur a hoon or somthing...but somtimes i ask 4 it when im in a hurry ;) lol
I dont look at others when I drive or when Im at the lights, so no I cant say that Ive been given the 'death stare'. I know that my missus stare alot at others at the lights though, always hear her saying did you say him - WDF was he looking at!!!! etc etc so yeah........
probly the fact that you and you no. plates was on the news not to long ago about having your car confiscated under hooning laws.
WWWDOT i get that sometimes aswell, just checking out the car i always think. although was passenger in my mates 32 yesterday when a p plate magna with a fully sick cannon and ralli art stickers decides to do the fly by with the passengers in there staring us down.... i just laughed at them! lil tossers
i can say in my silo im just a regular driver, in the 33 people want to drag me all the time..
i think people hear the turbo and it scares them to, ie. parents, kids
even if your not going fast.
hahah yea! crazyness
hows she going?
im good mate, got a 33 as well now hey :D
yeah mate shes going good, i put a cam in it, yeah got to sell the beast soon... get a wagZ.
yeah it was time for an upgrade.. :P
always get people asking me if i drift in the sil80 - go figure!! thanks all you drift kings on the streets. as for the line, always get the interntional sign langauge of 'spin the wheels' :P while other import drivers just snob me off like their car is better than mine - you know who you are!!!! whats with that?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
