the R32 and R32 V Spec brakes are identical, 4 pot sumitomo calipers over 296mm discs
the R32 V spec 2 brakes (and all 33 and 34 GTR) were 4 piston brembo calipers (larger than the sumitomos), over 324mm discs.
Hey,
Begging your pardon, but the R32 V-spec has Brembos. At least, my
V-spec (1993) does :P So:
R32 GTR - Sumitomo calipers, smaller discs
R32 GTR Vspec(93) and Vspec II(94) - Brembo calipers, larger discs
As far as I know, the only differences between V-spec and V-spec II are
that the V-spec II had different profile tyres and is newer. I have
heard mumblings about an active yaw controller (like on the 33 V-spec) but
haven't seen an R32 V-spec II diff to check (and I think it's just confusion
between 32 and 33 V-specs). Mine has no AYC that I can see.
I've never seen a V-spec II in the flesh. There was an article in a recent
HPI or Zoom, but they didn't photograph the rear diff (they did mention AYC,
but I'll believe it when I see it). I'd love for my car to be a V-spec II, but I
don't think that it is...
Regards,
Saliya
So the V-Spec AND V-Spec II run Brembos????
Which is it?
To the best of my knowledge:
The R32 GT-R was released Aug '89 and ended production in Dec '94 with 43,934 built (A figure which includes all limited editions listed below).
The R32 GT-R V-Spec: released Feb '93 through to Dec '94 with 1,453 built.
The R32 GT-R V-Spec II: released Feb '94 through to Dec '94 with 1303 built.
The are also 560 Nismo editions & 228 N1 editions (Different to V-Specs)
Both series V-specs as well as ordinary GT-R’s were built through to December 94.
The V-Spec 2 didn't supersede the V-Spec.
Both models had Brembo's & the active diff.
The difference is limited to the suspension.
Saliya,
Could you please post up a photo of your diff?
Edited by djr81
I'm almost certain the Vspec 2 was the only one with 245/45/17 tyres and the brembos. In fact the brembos do not even fit under the regular gtr 16" rims.
We go to a fair bit of trouble to log book the race cars as v spec 2 to get the larger wheels and tyres :)
Also I am certain that the active diff was never offered for the R32 it is R33 onwards only.
Saliya I think you will find someone just swapped your brakes at some stage, they are a straight bolt on and very popular swap.
The site that photo's off (http://www.gtr.co.uk/html/technical/r32.asp)
thinks that there were lots of different diff covers on R32s and also that
the only difference between the two v-specs was tyre size. There's
no mention made of AYC.
When I went looking for my 32, I was told by the folks at Mooroka
Autoshop that the 32 v-spec's don't have AYC.
But, as I said, I've never seen a v-spec II in the flesh.
Saliya,
I _knew_ someone would ask for that :) I don't have a hoist handy, so here's
what you get. FWIW it doesn't seem to have the huge finning that some
other R32s have, but I honestly can't see any hydraulics going into it. Next
time it goes up I might take more...
Regards,
Saliya
Nope, they certainly don't. My car has the 17" 'we produced with spartan air' BBS
rims and the Brembos front/rear.
I've done a little searching around and it appears as though "the almighty
Internet" says that _both_ R32 v.specs had 17/Brembos, and no AYC. So you
_might_ be logging your cars as v.2s for nothing :) Then again, the Internet
doesn't know everything (apparently, my car can do a 12.58 quarter _stock_).
Mine was originally advertised as a v.spec 2; but my understanding is that
with a build date of 93 it can't be that.
Just out of interest, where are you getting your info from (that only the v.spec 2's
had 17/Brembos)? Is there some Nissan piece of software that logs OE wheel
diameter against VIN (like FAST)? Should I be able to write to Nissan to get that
info ? I'd definitely like an authoritative answer.
Regards,
Saliya
V-Spec and V-Spec II both had Brembos standard.
Only difference between my V-Spec II and a V-Spec when I bought it was 245 RE01 tyres.
My V-Spec II diff looks standard, but has a flat (fin-less) cover, but thats as per all later model 32s.
The Brembos will fit under an OEM 16 GTR rim, you just need to massage the top of the caliper 2-3mm for clearence.
Look on your blue plate in the engine bay
under model number, mine says KBNR32RBRS8 AA.
The last number 8 means standard 17s. base GTR would have a 7.
To define V-Spec or V-Spec II (no difference in the model designation in the model number) look for B as the 6th letter, again base GTR would say X.
To define the rest, Nissan customer service in Japan provided the following when I questioned how genuine my car was, but I've never actually compared it to a base GTR...
K = Coupe
B = RB26DETT
N = Super Hicas
R32 = Build model
R = 2 doors
B = V-Spec/V-Spec II (base GTR says X)
F = 5 speed gearbox
S = Intercooled turbo
8 = 17" rims (based GTR 16" rims says 7)
A = No delete options (N1/Nismo would say Z)
A = Non N1/Nismo (N1 would say N)
well here is mine, 3/91 standard gtr
K = Coupe
B = RB26DETT
N = Super Hicas
R32 = Build model
R = 2 doors
X = base GTR
F = 5 speed gearbox
L = ?? it came with standard 16s tho
M = ??
Z = ??
G = ??
Hey,
I couldn't get the std 16" rims over mine; but that was without making any changes
to the brakes. I got some 16" slicks given to me, which is why I was trying... might
be worthwhile dragging out a set of rims and trying again if it's just a matter of
adjusting the caliper... but it didn't look like a 2-3mm change (the rim
locked up on the caliper about halfway on).
My model number has no '8' or '7' in it at all; it's KBNR32RBFS AA... any thoughts ?
Duncan kindly looked it up on 'FAST' for me, but it didn't say 'v.spec' or 'v.spec 2'.
Is this an RTFM question ?
Thanks,
Saliya
Hey,
Thanks,
Saliya
Saliya,
That id plate lines up with other V-Spec (Series 1's) that I have seen. Not sure what the eight is. All the plates I have seen have this particular character blank on the vspec (1's).
My poverty pack 89 model reads: KBNR32RXFSLMZG
My poverty pack 94 version reads: KBNR32RXFS7 AA
So maybe they changed how the plated were stamped at some stage...
The photo actually originates from a for sale notice on these forums! The car was a local (Perth) V-Spec series one that was advertised a few years back. I thought about buying it & now wish I had. One of the nicest I have seen.
Yeah the Brembos will fit under GTR 16s, but you need to remove a few mm off the top, particually a casting mark (a sharp edge in the middle of the caliper) that is fouling your rim. Removing the metal is very easy and its area you will be working on is well clear of any unseen internals.
For good measure we took a few extra mm for greater clearence. Its still a tight fit, but works great and looks better filling the rim.
Is grinding calipers really that good an idea though? Also if they are such a tight fit, do you see there ever being a problem if a stone etc gets caught between the wheel and the caliper???
Just a few things that would concern me, LOL but i have never done it so dont really know:)
Ah, I see. I don't really want to be altering the caliper in that fashion, but useful to
know. Still trying to find out what my 'blank' or lack-of-8 means, but I found this
pic (anybody read Japanese ?) It _looks_ like the 'B' in 'KBNR32R_B_FS AA' means
'17 inch wheels' ...
SW
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
