  • Replies 79
Year: 1999
Colour: Pearl White
KMs: 95000
Mods: Nismo panel filter, Blitz FMIC, CES split dump/front pipe, Fujitsubo cat back, Nismo 480cc injectors, R34 GTR fuel pump, R34 GTR fuel regulator, Chipped ECU, GCG highflow turbo, AVC-R, full respray, rebuilt transmission to handle 300rwkw.
RwKw: [email protected] bar
Now has blown engine as latest mod.
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635608
Year: 1998 Series 1
Colour: Nismo White
KMs: ~40,000km
Mods: (performance only)
K&N Panel Filter
Trust PEII Cat-Back Exhaust
Manual Boost Controller @ 10psi
Front Mount Intercooler
SAFCII D1 Limited Edition
Iridium Spark Plugs
Voltage Stabilizer Kit
FMIC and Radiator Cooling Panel
SAU STICKER - 20rwkw alone :P
RwKw: 196.4rwkw @ 10psi
Dyno Graph (if any):
There is one, can't be bothered looking for it (it's on the forum somwhere).
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635668
Year: May 1998
Colour:Black Pearl (GV1)
KMs:120thou'
Mods:
Nismo 300km cluster
Nismo replacemet gauges for boost/volt/oil temp
Apexi avc-R
Apexi Safc II
Apexi ECV
Garret GT30 with external 38 mm TurboSmart ultragate
Full 3inch exhaust with 5Zigen muffler
Z32 afm
Splitfire Coilpacks
oil catch can atmo
bosch 040 fuel pump
brake cyclinder stopper
HKS oil cooler relocation kit
HKS air filter
HKS Hiper D coilovers
Greddy FMIC
camber arms
aftermarket rear sway bar
Carbon Ztune style bonnet
Carbon eyelids
18" BBS LM wheels
RwKw:
220 kw at 0.8 bar
Pics (if any)
Edited by E_Lu-SHuN
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1635712
Year: 1998 Series 1
Colour: Black GV1
KMs: 114,000
Mods:
RwKw: was 350rwhp on RB25 engine
Pics (if any)
well done ian thats a crazy gtt! awesome website too very useful as a gtt tunning guide!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1643912
Year: May 1998
KMs:120thou'
Mods:
Nismo 300km cluster
Apexi avc-R
Apexi Safc II
Apexi ECV
Z32 afm
Splitfire Coilpacks
oil catch can atmo
bosch 040 fuel pump
HKS air filter
Greddy FMIC
camber arms
Carbon eyelids
18" BBS LM wheels
RwKw:
220 kw at 0.8 bar
Pics (if any)
mmmmm sedan goodness....
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644038
Year: 1998 coupe
Colour:black pearl
KMs: 63500
Mods: Blitz FMIC, 3"exhaust with split dump, Airfilter and nismo clear indicators front and side.
i need to put a tunable ecu on it becasue std ecu hitting rich retard mode, but i have an auto Any Ideas???
No pics as yet dont have a digital camera.
have no idea how much rwkw, but for a near stock car it flies!! I love It!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644196
Year: 1998
Colour: White (not the pearly one)
KMs: (87000kms)
Mods: 3" Turbo Back Exhaust with Split Dump Pipe, Cold air box with pod filter.
RwKw: not much more than stock
Dyno Graph (if any): none
Pics (if any): see signature link
Cheers!
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644557
Year: 1998
Colour: Sonic (or Athlete, cant remember) Silver
Kms: about 46,000
Mods: 300x600x75 FMIC, Apexi Pod Filter, Greddy Turbo Timer.
RWKW: I guess around stock.
Dyno: none
Pics: in my sig.
Edited by RyanN
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1644948
See what I mean about confusing :O
There is a NISMO kit and a seperate Nissan Motorsport kit which are 2 different kits. The Nissan Kit fitted to yours was available as an add-on when you bought your car (like a sunroof, colours etc). The NISMO kit wasn't, it had to be bought seperately.
https://www.sau.com.au/forums/topic/90814-r34-gtt-owners/#findComment-1645351
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
