Just had a ride in my friend's new MX5..........damn the car feels powerful with good power to weight ratio........
Now I feel my skyline doesn't have enuf power (which it doesn't)........so unsatified with my current power............im gonna be in a slump for a while
https://www.sau.com.au/forums/topic/90923-the-new-mx5/
Engine type 2.0 litre in-line 4 cylinder 16 valve DOHC S-VT
Engine capacity cc 1,998
Bore and stroke mm 87.5 x 83.1
Compression ratio 10.8 : 1
Maximum power kW 118 @ 6,700rpm
Maximum torque Nm 188 @ 5,000rpm
Throttle control Electronic (drive-by-wire)
Fuel system Electronic fuel injection
Fuel tank capacity litres 50
Fuel consumption man (combined) 1 l/100km 8.5
auto (combined) 2 l/100km 8.8
Recommended fuel Premium unleaded (min. 95 RON )
https://www.sau.com.au/forums/topic/90923-the-new-mx5/#findComment-1638076
Yeah the MX-5's are a great drivers car. Its a shame they can be underrated as a performance car as you'd only rarely see a nicely modded up one as you would pretty much see them in the hands of some toorak or south yarra dude who only bought it because it was a convertible and has kept it stock standard for the past 10 years being blind to further modding.
Comparing it to my R32 GTSt I've driven both the NA and NB series MX-5's they are piss weak but they feel alot more chuckable around corners even though they are relatively underpowered. they'd be a really good slightly most costly alternative to an AE86 if you looking for a light NA rear-wheel drive car.
they aren't as fast in a straight line (but then again I'm not into drags at the traffic lights, no skill in that.) but they are awesome on the twistys. :)
they'd be a good drift weapon if given a good balanced setup.
https://www.sau.com.au/forums/topic/90923-the-new-mx5/#findComment-1638216
not sure about the specs, but apparents she had the limited edition of the MX5, bilstein suspension...... I think its about 160 hp and 1100kg......AND
7 thats right 7 CUP HOLDERS!!!!!!!!!!!!!!!!! and I could seriously use one in my car.
https://www.sau.com.au/forums/topic/90923-the-new-mx5/#findComment-1639600
Anyone see the ad in drive for the new mazda 6?? 190kw and 380nm torque at 3000rpm wwttff thats nuts how can they get that amount of torque at such low revs?
Modern turbo cars are getting better and better at producing massive torque at low RPM. The old school of turbos were laggy and needed revs revs revs to make power, while the NAs made the low RPM torque. Now the opposite is true, with high powered NAs needing RPM to make big numbers, and turbo cars making huge torque at very low RPM.
Some of the more rediculous torque figures are from small modern turbo engines:
Holden Astra Turbo: 250Nm @ 1950RPM from 2.0 litre 4 cyl
Volkswagen Golf GTi: 280Nm @ 1800RPM from 2.0 litre 4 cyl
Saab 9-5 Aero: 350Nm @ 1900RPM from 2.3 litre 4cyl
And just to make them all feel weak:
Bentley Continental GT: 650Nm at 1600rpm
Mercedes SL65 AMG: 1000Nm at 2000-4000rpm from 6 litre V12
Bugatti Veyron: 1250Nm at 2200-5500rpm from 8 litre W16
The 4 banger creates max power at 5500 so it probably redlines about 6, so max torque would be around that area.
Power is dependent on both revs AND torque, so peak power does not necessarily appear near peak torque.
why oh why doesn't Mazda put a rotary in one damnit!
This was for sale a few months back:
13B Rotary MX-5
Alternatively check out the Bullet Roadster. Basically an MX-5 with a 13B, 20B,Lexus V8 or supercharged V8. Bit more expensive than the standard MX-5 though! Mazda will never make a rotary MX-5 because it will eat into RX-8 sales, and perhaps the rumoured upcoming RX-7.
https://www.sau.com.au/forums/topic/90923-the-new-mx5/#findComment-1639958
I have a reasonably modified 1989 NA6CE MX-5 (imported Eunos Roadster actually), as well as a newly complied and registered R32 GTR with HKS GT2530's and supporting mods.
The MX-5 is much fun it's criminal. Different sort of fun tho - and I'd actually take the MX-5 for hills driving.
The GTR is just insanely powerful and efficient, but the MX-5 is supremely fun to drive. I think my next car will be the new MX-5, modified of course :O
https://www.sau.com.au/forums/topic/90923-the-new-mx5/#findComment-1641115
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
