Hi Sk. I'm pertty sure both bolt holes were the same depth, quite deep that is.
If you were to try rotating it off the car you should be able to do it right? I might try and put it in a vice and see if I can rotate it.
Thanks.
As you can see from this picture the LHS bolt has bottomed out, use that to rotate the eccentric crush tube. The lock nut is then tightened.
:( cheers :laugh:
  • Replies 93
Hey SydneyKid / Others.
What about this style pictured below? I have never seen them before, but I was getting a wheel aligment done and the guy was recomending stuff and said much the same as you...however he added that these were good, even if they are $1600 a pair! (ouch)
The ones pictured are 'cheapies' I found after a 5 minute search. They are $325 NZ. The 'good' ones are the brand "midori" not sure if that refers to the brand or the style. But maybe you can shed some light on the topic.
BTW, if you do review them, put it on the front page perhaps?
Cheers
Chris
Me and a mate have got these. Got them off yahoo auctions for $500 delivered if I remember right. Some generic jap things.
They're good, plenty of adjustment, but are pretty harsh for street use.
  • 3 weeks later...
:( cheers ;)
Hi Sydneykid
I've been trying to correct my camber on the front of my r33 gtr but without luck. I have -1 deg on left and -2 deg on right and the suspension is stock v-spec. I apparently have no camber adjustment on the front of my car (according to Tyrepower) but then I saw this picture of the yellow whiteline bushes installed on the front of an r34 for camber adjustment. My car looks like it's got the exact same yellow bushes on the front.
Does this sound like my camber is adjustable ? If so how are they adjusted and how could I find out if they are infact a whiteline front camber kit ? I am concerned as I run 275/35 Advan V103 tyres which they slug me at $680 per corner and don't want to wear them out. Any help would be great as you seem to know your stuff and I know not a lot about suspension. Cheers
Hi Sydneykid
There are non adjustable polyurethane camber kits available. There is a simple way to check, take a look at the above picture and you can see the bolt on the LHS of the arm is bottomed out (protrudes) and it has a lock nut. The non adjustable bushes don't have the protruding bolt and the lock nut (ie; the LHS of the arm looks the same as the RHS of the arm). It is most unusual though, very few non adjustable kits are sold.
I should mention that a tyre service is not the best place to get a wheel alignment, try your local suspension workshop. There is a list of recommeded ones in the various Group Buy suspension threads.
:( cheers ;)
:( cheers :(
Thanks for posting back. Mine have the protruding bolt and locking nut on the arms. On drivers side arm the protruding bolt and locking nut is on the left (towards the rear of car) and the passenger side arm has the protruding bolt on the right (towards the rear of car also). Does this sound correct ? Has someone put them in wrong ? Also being in Alice springs I'm very limited to where I can go to get wheel alignments done, there's like 3 places.
My setup does look exactly like the picture on the drivers side though. Really annoys me if the are adjustable and no one has picked up on it after 7 wheel alignments.
Most tyre services have probably never seen adjustable camber bushes on a Skyline and so have no idea what to do. Show them the adjusting bolt and the lock nut. When they undo the lock nut and turn the adjusting bolt, the camber will change (amazing).
:( cheers :(
Has anyone purchased / used a set of these yet ? If yes, and they good quality ? Much adjustment ?
They are on eBay ( USA ) and are pretty expensive but look the goods.
* Sorry if this has already been posted *
^ castor rods right?
Well im using just jap one and found them to be good quailty..
I noticed a hell of a difference from stock bushes to rods, esp at high speeds around a corner.
(but im now use to it, esp the bumps you feel)
Sk do you feel that this is the same for castor rods? That is, its worthwhile buying adjustable bushes, than rods?
OR anyone else? I have been using jusjap ones for a long time now (1 year maybe??).. No problems..
But worth going back to adjustable bushes? your thoughts anyone?
It a personal preference thing, some people can't stand the increased NVH from sperical bearings. Others don't seem to mind (notice), until they get into a car with out spherical bearings and then the notice the lack of NVH. The truth is very FEW people will ever notice any improvement in handling from using spericals over polyurethane. But MOST people will notice the increased NVH.
(NVH = noise, vibration and harshness)
>_< cheers >_<
Be aware that using front adjustable upper arms still means that you have rubber bushes in the outer joint on R33's and R34's. Similarly rear adjustable upper arms still mean that you have rubber bushes in the outer joint (R32/33/34). Plus you will need rear traction arms well, and (you guessed it) you will still have rubber bushes in the outer joint.
So buying adjustable arms doesn’t get rid of the soft and/or worn out rubber bush problem.
:huh: cheers :laugh:
If you didn't go with the rotating bush to adjust front camber, what would be the best design for an adjustable front upper arm for a R32 GTR? Maybe something like the "midori" ones with a polyurethane bush? I assume it would need to be very rigid.
While I am at it, how is castor changed in a R32 GTR?
I have yet to see a perfect front upper arm design for R32's. Nissan obviously agreed as they went to the wide spaced arm on R33's and R34's.
Caster is adjusted via the radius rods, offset bushes in the front of the radius rod being the best solution for a car that does any road work.
:huh: cheers :O
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
