hey guys im looking at a 33 gtr, im just wondering, whats the build quality like in these cars? are they solid?
also are they reliable? do they require much maintenence? do they need much work if theyre near standard (ecu, exhaust, filter)
what are some common problems in r33 gtr's?
also what do you think is the best way to buy? imported or buy from someone private?
how does the r33 drive? is a good street car? can it go one track? how does it compare to say an evo 7?
cheers
Build quality is good. The RB is very strong and mod friendly.
Reliable depends how well maintainted it is and how far you push it. its a sliding scale.
if its near standard doens't need much more work than any other car. oil changes every 5,000ks with good oil etc....
Common problems, dont really know... make sure you get a compression/leakdown test before buying... don't pay any attention to km's on the clock most imports have been wound back.
Would you feel comfortable blowing ~40k on a car you've never seen or driven? i know i wouldn't, i'd prefer to buy local first, but if you can't find what you're after local you could look to import...
I drive my R33 GTR to work daily and track it on club track days without changing anything, drive on track, race drive home etc... but mine is pretty standard...
evo7 never driven one can't say sorry.
To give you some idea, stage 1 mods on a GTR includes exaust/cam gears/ecu/more boost on std turbos and you'll make about 250rwkw.
i would say the gts-t is a much better street car than the gtr
The gtr is more of a track car. It is laggier in stock form than the gts-t is.
The evo 7 is a much newer car and you will probably find them to be in better condition than the r33 gtr
Build quality RB26DETTs are great engines. The only downfall with the GTRs are maybe the maintainence costs. You got 2 turbos to look out for. It is an AWD so many more moving mechanisms?
Near stock standard they are really fast enough. Zorst, ECU, injectors, up boost and you can go pretty damn fast.
If it is a daily, then you might need to look out for fuel consumption. They take quite a bit of fuel.
Not many GTRs that are for sale now therefore choices are minimal. You can try importing one :D
I was under the impression that if you were too Import a car it would be considerably Cheaper than buying one in Australia.
Aka - 40k for a 33 GTR in AuS
-20-30k For a 33 GTR from Japan
Obviously you flip a coin to see if you get a good one or a Lemon from Japan but am I wrong about pricing?
ive been doing alot of hunting, it seems imports are alot cheaper, so i guess this just means we need a broker that can be trusted, and looks at the car over there inside out and maybe even does mecanical tests? is there such thing? i think imports101 does something like this, anyone else?
GEARBOX SYNCHROS.......the 33 GTR seems to eat synchros, you probably won't notice it on a test drive as it only seems to occur once the gearbox is very hot (and believe me it gets fooking hot, girlfriend thought I kept leaving the heater on), the upside is that it heats your drafty garage :P You will likely notice the gears crunching from 3rd to 4th or 4th to 5th. There is a temporary fix which involves using Redline Heavy Shockproof gear oil but ultimatley you'd need to have the gearbox out and replace synchros (they're only a couple of hundred bucks but it's the labour that kills). Other than that watch out for fake V Spec's and very standard cars as they're sometimes ex raced ones that have had standard bits put back in. Don't let these things put you off though, I've had mine for 10 months now and I absolutely love it, it only cost as much to run as you want new shiny go faster bits!! I'm addicted to modification so spend all my expendable income on it....with no regrets :)
G'day mate,
I found this stock '96 HR33 GTR V-Spec down in Sydney, pretty good price compared to what I've seen around, thought it might interest you if you're looking at buying one locally (I was going to but my loan requires the car to be 8 years or younger :rolleyes:).
Click here
Question, does anyone know the kw of a stock HR33 GTR? Or of all Skyline models?
Cheers.
Edited by SHT HOT
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
