im going with the vipec because its one they always use .. who said it would always be a streeter ? :thumbsup:
i was !! but after today i spent a few hours looking into ecu's and other items
so now my car will be going down to CONFIDYNE
for a motec or maybe haltec ecu and dyno tune .
as for the mods there still from befor install turbo . timeing belt . nice clean up new fluids .. maybe fuel pump and some little bits nothing to big :cheers:
Hmm I would be keen for a dyno run to get a 'before' statement before I hit engine modifications.
What sort of ride height should I be looking at to actually manage getting on the dyno :whistling:
If you can fit your foot under the car it'll get up there.
I wouldn't bother with a motec, you pay a pretty big premium for no extra features, and the ones with the extra featues are $3000-$5000.
Just wondering if you have contacted Boost in Launceston for a ecu/tune? Just seem a lot of hassle to go all the way to ulverstone.
hey mate. you are oviously new to this but there is more than one place to get a haltech or motec instaled around tas and for quite varying fees.
a bit of experiance has shown me that dealing with one good workshop for all work is by far the best way to get the most out of a car and enjoyment. all tuners will tune any car off the street but they are unlikely to put 100% into the job. if the workshop does all the mechanical work to a car they will then know that the engine is in sound condition, or maybe a bit tire,. also that all parts have been installed correctly thus allowing them to put a bit of back ground knolage into the performance of the car.
if you was planing on getting workshop a to do all the work then decided to get workshop b to finish it all off do you think workshop a is gooing to put its extra bit of effort into the job. if you want what workshop b does then maybe consider getting it all done by them.
in your case workshop a has already lead you down the wrong track so whats to say they are doing anything wright. this is only assumed from the info given by you.
every one on here is right in saying that a nistune will give you by far the best bang for buck at this stage. but non of them have pointed the out possibly the cheapest and best place to get one. you just have to look around a bit.
what ever you do dont get Motec's new budget plug in ecu. it is rubbish and hard to use compared to the likes of vipec and haltech
i would only ever run a Motec if i was running a top top end race car. they just arent user friendly enough for amature racing. haltech, vipec, link most of these will do 100% of what any amature needs.
you seemed to listn to the advice from before so hopefully you will have a bit of a think about your next step to.
im thinking of changeing . as my tuner now cant keep going with my needs so there just installing the turbo kit for me and doing the service .. ulverston is slose for me the hobart one i dont trust the dyno tuner up here ..im calling them monday wen i was talking to them they said the platnum ecu and haltek only come in that from wat if hurd they are working on a 33 and other nissans so a know there got there foot up in there in wat i need unlike mine that are more v8's if they where to tune it for me i would keep going back thats why im not getting my machanic to install the vipic then go somewhere new and ask for a dyno tune i would like one dyno tuner to do the rest of the work for me yer i should have started with them but as u said im new pinch.gif
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
