Yeah i have a set , the reason i have the gtr rims on the back is because i was trying to fit the 9s' on the front (the fronts are only 8s') . I really want some meister s1s' or something , probably with a black center for something different , i'm a bit over chrome . Those wheels will probably end up on the 32
The ti as it sits now with all thew coilovers, all s13 front suspension, r33 gts t 4 potters, n12 rack ends, s13 tie rods and all nolithain bush it the back
Yes I need to do somthing about the offset on the rear but Might just have to get 35mm bolt ons soon cause moneys to tie up for better offset and width rims
Also got bored and did a garden edging lower lip
Edited by lawler
yeah only reason i went bright is cause the car is black and cant really clash lol... will be getting slammed when i burn these tyres off, then ill get the guards done so i can fit some 245 or something at least under it, 225's dont do it justice from behind haha
how my old girl is sitting at the moment.
Awaiting an oil change, cam covers re installed & a few front bar mods/wiring fixes, should be on the road again by the end of the weekend thumbsup.gif
would you guys advise using bolt on spacers or slip on for 33's?
wanting to pump my wheels out a little before getting some new ones.
Edited by Autumn33
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
