Removed all this:
To have a look at this:
Not too bad compared to what others are finding, will also check the other side while the bumper and the other bits are off
Anyone good at fixing rust? Want to earn some cash?
Removed all this:
I gotta do mine as well not looking forward to it one bit
got a set of semi slicks today cant wait to get on the track and test them out :yes:
You will love them, they make a fair bit of difference. Just make sure you warm them up properly before trying to break any records ;)
This is true, or you'll end up like Veeto.
so installed my new whiteline sway bars i got of Daleo ( on here) GB ... prob best bang for ur buck thing i have ever done !! handles so much better steering is direct traction as shit loads better and doesnt single pegger like it used to !! so if u want sways bars a bit cheeper hit him up well worth it
on a diff note changed my diff oil 160k later it was like water pinch.gif so i changed that after we went for a play with the new bars :thumbsup:
just need to ask one thing how many L does a rb25 box hold or is it just best to fill it till it starts to come out the fill plug like a diff ?? :thanks:
I just bought another skyline (R32) , needs some tlc but should make a good track hack/daily :) ,the body is rough but the mechanicals seem really good
pic of said vehicle :) , i wanna swap the kit for standard stuff incase anyone hasn't read the wanted thread :)
So I cut into the rust hand now my car has a big hole
Who wants to make some $$$ and weld some plate back in?Im thinking about buying a cheap mig and giving it a go myself but I know that the thin steel and lack of experience will be a bit tricky
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
