Well got my floor pans stripped and cleaned up and Brodie got it painted Sunday. Cage is in, seats back in and inner lap harness anchor points mounted into the tunnel with plates etc. ISC strut tops on the bilsteins now, more travel better height adjustment. Still bit left but slowly crossing stuff off the to-do-list. Giving lexan rear screen and door screens serious thought. Not a huge amount to be gained but every bit counts. Also Mr Kuc confirmed ID2000's work with PFC's so that's a bonus E85 won't be too far down the track. AFM will be the only real restriction. Can't wait to get back into the snotter and get out to a SAU day
You could get away with ID1000s and bump up the fuel pressure. Thats what I did with mine. Was good for 475rwkw thru the auto. Brad makes well passed 500 with his
yeah to be honest mate thats prob all I'll run. I know a few blokes on the mainland making 390ish on nismo 740's at 3 bar, so 1000's will be more than enough. For me anyway!
I always think i need more power when i havent driven it in months but usually when i get back in it on the twistes or basky i shit my pants with 17psi/320rwkw's hahaha. touch wood the new suspenion setup and improvments allow me to run more and gain something =)
haha and new rear tyres matey. yep, there has been some looptey loops in her, it was manbearpig.
the last thing that i really want before I'm gonna be happy (for awhile anyway) is a good adjustable rear diff. Still, the improvements to the rest of the old girl should make it easier to cope with whats in it.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
