  • Replies 42
Holden are bloody lazy. I loved holden until ford released the XR6 Turbo. Thats when the respect came from. Holden UNTIL TODAY still hasnt created a rival turbo car to compete against the XR6T.
Rumour has the VE Commodore (replacement for the current VZ) will have the option of a twin turbo V6, similar to that used in the Torana concept car.
another huge ford fan here. not bad, although, i think ford, in the current automotive climate (ie, coupes, turbo's and drivability being issues ppl look at nowaday's rather than pure cubic inches), would do well to release a cutdown 2 door, based on the falcon chassis (just like the monaro from holden), with the 4L turbo 6, and awd.
did someone say Ford GTR? :)
I thought waaaaay back when they announced the Territory that by the time the BF update came around they would be making all wheel drive falcons. I am really suprised that they haven't done it. Even though the AWD system is Auto only, a 6 speed automatic AWD falcon with Turbo 6 or V8 power would be incredible. They should wack a blower on the V8 while they're at it too - it's just a matter of dipping into the Ford parts bin,
I think they took note of how badly the AWD Magna flopped.
Very similiar to the AU's ugly front end, they quickly changed that, what do Magna go and do.. Make model after model based on the same fugly headlights.
Edited by Cubes
F*CK the focus, i want my Esky!!
Im seriously thinking about going over there to live for a year so i can have one :(
If someone offered me one of these OR an R34 GTR, i would dead set not know which one to pick :(
B)
I've always had a leaning towards Holdens but after the Ford Turbo range came out I converted :P
Btw, whats a better overall package in terms of power and handling?
Ford Typhoon or the Subaru Liberty GT?
Both are very yummy and if i had to get a family car it would be one of those.
If I had to buy a big sedan, I'd get an XR6T and do my own tweaks to it.
But then, if I was buying a sedan my priorities probably wouldn't be to get a very quick car, and I'd take the build quality, interior trim, and fuel efficiency of an Accord Euro or Liberty GT over the superior pace of a Falcon or Commodore.
absolutely! one of the best Australian built car on the market! a mate did chip, full exhaust, air and fmic to his xr6 turbo, bang! 296rwkw! all for $4.5k! beat that
I love to see intelligent open minded conversation on our forums
i think hes just trying to turn this thread into another potentially meaningless debate lucky this is not an holden or ford forum
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
