Chaser spotted
I saw my first chaser (Mk4 I think but dont quote me) today whilst launching the boat to go fishing :rolleyes:
This was at the boat ramp at the end of Katanning street just off Guilford rd. If you know your geography this is on the same street as A&B auto's who are a compliance mob. It was black with chrome deep dish 5-7 or so spoke mags and was a manual with blowoff valve.
I could tell it was a manual and had a blowoff valve cause the driver was umm erm testing the handling characteristics of the car:rolleyes:
I'm not sure if it had dealer plates or not so does anyone know if they can be complied as yet or is the sevs procedure still being gone through?
Anyways it was bloody schmick, sounded awesome and although very camry/cressida looking it made me look 5 or 6 times.
P.S. Ken your GTR hasn't moved from the front carpark since Tuesday except to bring it in at night. Dont be suprised if they take longer than quoted...again :D
https://www.sau.com.au/forums/topic/9155-chaser-spotted/
I thought that C Red has a black chaser ?
Not up on ny Toyotas but know its some 2jztzettdohc type thingo.
Car will take longer cos theres no front seatbelts in Perth. Will be ready mid next week.
Cheers
Ken
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-137313
Hi Rhino,
As of now there was only one importer who could get the Chaser 2.5twin-turbo (JZX90) in, and that is Cannington Auto Wholesale, Frank is the owner and I think the cars go for $25K. I do believe that C-red are bringing them in soon, as they make awesome drift cars. The Chaser, Mark II and Tourer V are all the same car with minor differences.
There are also a number of LX90's , which is a 2.4L diesel turbo , my mate owns one, they look good, use F/A fuel but have no real performance.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-137390
GTS-4OrCeD,
Unfortunately most of the ones around are LX90's, the turbo diesel. You can tell as they have the down-turned exhaust. The 1JZ engine is fantastic, what I used to have in my Supra, so although they don't look quick they can hand your ass to you if you don't expect it.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-138201
i have a jzx90 mark2 its is modified 5 speed.
i was a bit worried when i bought it but it has supassed every expectation and more let me tell you this thing should be abale to pull a 12sec quarter for those who want more info post here i will reply
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-138249
Guys,
My Mark II is a JZX100. I also had a Mark II JZX90 which I got rid of. Both the 90 and the 100 are available in Chaser, Cresta and Mark II, with different front and rear ends basically. As a guide my JZX100 has 260 odd rwhp and is as quick as the GTAAH rolling start. Its fcken nuts. We'll have compliance available for the JZX100 within 2 or 3 months.
Jash
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-141561
Hey vspec i was driving an import b4 u were an itch in ure daddies crotch!! j/k :sperm: so for all us ppl who dont buy mags. 1.4 ton? or same a supra? ya know how toyota love the "solid build" lot more than i can say for nissan tinnies and their "lets save weight and put in a weak engine"
*stir stir*
https://www.sau.com.au/forums/topic/9155-chaser-spotted/#findComment-141587
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
