Please find a copy of the Supplimentary Regulation and Entry Form Here:
Entry Form - DECA Version2.0 Entry & Supp Regs
Removed for now.
Event Schedule - Released 1 week prior to event
SAU VIC have arranged for DECA Version 2.0 Motorkhana / Driving Day for SAU and WRX Club members and affiliated car clubs. We will need your commitment early in order to secure a spot. This event will give all entrants plenty of track time and will be highly enjoyable. If your new to motorsports this is the perfect opportunity to give it a shot.
Date: Saturday 19th November 2005
Location: DECA driving grounds in Shepparton (145 Wanganui Rd)
Cost: $60
Entrants: Limited to 55 to give everyone maximum track time
Time: Gates open 8:00am, Scrutineering 8:00am-9:00am, 9:00am Driver Briefing (Compulsory Attendance)
Last timed run 4:30, Closure of gates at 5pm
Events we intend to run:
1. 2x Full Skidpan Motorkhana’s (Witches hats on large skidpan, with map provided)
2. Short track sprint using the DECA track (Slowed down by chicanes)
3. Mini-Sprint (new!)
4. 2x Skidpan Challenge (2 cars on skidpan.)
5. Open 2min Skidpan (pending time at end of day)
All events should have a minimum of 2 runs each. For those that came last time all events will be different but will be designed in the same spirit (i.e. fast and flowing rather than tight and complicated)
There will be no stop-goes on the short track, there will be no reversing sections on the skid-pan, and the skidpan will be dry (weather dependant!)
Helments will be required for the 2 back sections only (not on skid-pan) and 1 passenger can be taken in all events.
SAU will provide a BBQ lunch at a small cost and tea/coffe, cold beverages will also be available for purchase.
This event will run under AASA, and a minimum of a CAMS Level 2 Non Speed Licence will be required, or equivelent AASA licence. These can be arranged on the day for a fee of $45 if you don't have a license already (One day event license).
SAU Vic are now accepting entries!!
This day is Proudly Brought to you by AFAS Automotive Services
If you want to know what the day is about check out a few video's from out last one.
Skidpan 1
Full Skidpan
Challenge 1.
Slalom
Challenge 2.
Skidpan Battle
As of this morning there are only 8 spots still available for this day. ;)
Ok - this event is now officially fully booked!
All future enquires will have to be placed on a stand-by list. Given that we are still 30 days away from the event there may be some withdrawals closer to the date - but we probably wont know until the last week or so.
Thanks all for your support.
Cheers
Since we have a few non SAU and WRX Club members entered I've been asked to post a list of confirmed entrants for reference.
So here it is.
Name Car
Andrew Richmond GTR
Blaise Paris***2 STI
John Yong STI
Joel Strickland WRX
Michael Budge Commo
Dane Stokes S13
Ben Prendergast STI
Richard Ringleben Golf Gti
Garry Matthews WRX
Grant Walkley STi
Jarrod Moore GTS
Shan Morthy GTS
Craig Moor Celcior
Ben Lippa 180SX
Nick Eldin GTST
Anthony Snelling GTST
Tom Giordano GTST
Alan King Liberty
Natalie Peebles WRX
Kylie Cummings***2 Cheater Car
Luke Margocsy GTST
Blair Strickt ?
Darren Smith ?
Peter Mongomery ?
Justine Schuller S15
Mary Ward Forester
Steven Dean STI
Jordan Walsh WRX
Chris Thomson GTR
Troy Brisby GTST
Tony Baxter Mirage AWD
Peter Blythe GTT
Matt Lowth WRX
David Mocnay 350Z
Darren Golding WRX
Will Stark**1 WRX
Adrian Hard Yellow POS
Steve Crouch WRX
Matt Mak STi
Peter Fuller STi
Jason Hornbuckle WRX
Adam Crew WRX
Ryan Bell 180SX
Christopher Ohanian WRX
Ross Sedawie WRX
Simon Williams WRX
Dave Marinucci Taxi
Aaron Foo RX7
Peter Yandell WRX
Peter Canfield WRX
Helen White**1 WRX
Bree Barnett 206CC
Alan Caleija GTS-T
Scott Bailey TX5
Juck Kuzior 240Z
Still in discussions Geoff - but it looks like this event will be covered by a TV station. (ok - Channel 31 but still!)
And the rights of that footage will actually belong to Serious Business (makers of Serious Performance and a number of other publications).
But more detials will be posted as they come to hand.
I suggest that for the 'open skidpan' you still put a couple cones on the skidpan so that people have something to aim at. Sliding is not as much fun if you're not aiming at something ;-)
ps. I'm looking forward to the day ... I'm sure it'll be fun.
Edited by DavidM
After doing some calculations, there will not be any time for an open skidpan unfortunatly. With 56 entrants doing 2-3 runs per event and 6 different events, the day will be jam packed from start to finish. Lunch will even be difficult to squeeze in.
Keep an eye out for the 'event schedule' I will make this avaliable mid to end of next week.
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
