  • Replies 181
Posted Images
Cheers ben for the wicked hid kit :D
Picked it up this morning and spent pretty much the whole day installing it with my mate, he got his on no probs but with mine for some reason my left headlight just refused to work. My first thought was that the fuse was gone, but checked every single fuse under the dash (they were all in jap) and in the engine bay and all were fine... after that spent a LONG time just trying to figure out wtf was wrong, till finally gave up and just drove home.
Later I searched the forums to see if I could find out what was wrong, and straight away came across a thread which said that the fuses for the headlights are actually in the boot.... and sure enough the fuse was broken... so yeah just a helpful piece of advice if any of you guys get into my situation when installing ;)
oh and btw ben, my car is turbo if u didn't figure it out at the time :D hahaha
hey mitchy n the collora owner, sorry i've been asked the company but they said if i send them by four then the postage will be very expensive. so if i can send them in this month with all the other ones?, i'll pay for ur postage for the responsibility of missed ur order.
sorry about this .but pls wait okay?
yeh KeeFy
http://viciouspower.com/racelights.htm
$650 for this pair not including the batterys :S
most of the kits ive seen start at arount $400, and upwards to $1200
went riding last sunday at night, with a few guys who had them, they are totally insane, the HIDS just light up the entire track..its like gandolf riding around heh.
