main advantage that i can see is the ability to have vents for cooling, not that many of the cars that i see driving around that have carbon fibre bonnets actually require any more cooling than stock...
don't say weight is an advantage, as the weight difference between the carbon fibre bonnets that you can buy retail, and an aluminium bonnet, is next to none...
Its mainly for the 'look at me' wank factor
https://www.sau.com.au/forums/topic/91912-bonnet-pins/#findComment-1684976
I'm not sure about the 'retail' cf bonnets being no lighter than the stock aluminium item, surely they are lighter if not only by a little. Aren't the carbon fibre bonnets that you buy 'retail' just a layer of carbon fibre glued on to a fibreglass bonnet anyway? My brother had his cf bonnet fly up while driving (he's got 2 heavy catches to keep it in place now!) and the guy he took it to couldn't believe that you could get a sheet of cf that big (bonnet) for about $1000. True cf would be a weight advantage though wouldn't it?
I guess if you are looking at a cf bonnet to save weight, there's much cheaper alternatives to spending 1 grand. (good bye interior pannels and rear seats!)
"They taste like burning!"
https://www.sau.com.au/forums/topic/91912-bonnet-pins/#findComment-1690154
I think full c/f starts at around $4k.
The big issue with c/f bonnets is how they break in an accident, because they shatter instead of fold like metal they can end up coming through the windscreen and seriously injuring the driver and passenger.
But, they look sweet and are pretty cheap at 1k so why not?
You should always get pins with c/f or fibreglass bonnets incase they fracture around the bonnet catch.
Race and Rally sell them in Aus, but I'm pretty sure all the autobarn, super cheap etc etc etc do to. There is nothing to them, pins, catch and 3 rivets so quality is not really an issue.
https://www.sau.com.au/forums/topic/91912-bonnet-pins/#findComment-1692788
You will find that if you rivet the pins to the cf hood they will pull through very quickly as the cf is very "soft" when there is an open edge showing.
I have this problem and i'm going to be fibreglassing some nuts on the inside of the bonnet so i can screw some bolts into :D
https://www.sau.com.au/forums/topic/91912-bonnet-pins/#findComment-1712040
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
