can someone post a pic of the starter motor location?
i want to check its connection...
i recently has a walbro pump installed, and when i turn the ignition during prime sometimes i get nothing for a couple of seconds before it turno over
but once prime has finished it cranks straight away..
then again, sometimes it cranks fine!
only happened post-install of walbro by worksho[
cheers,
Warren
Sounds like bad connections some where.
There is no way a small motor like a fuel pump is going to bother a starter motor. If anything at all the starter motor would take the power away from the fuel pump due to the starter having a lower winding resistance than the fuel pump.
  • 1 month later...
After all the talk of upgrading the wiring to use the std wiring to power the relay and wire the battery directly to the pump... Has anyone ever considered that even if you use big 8GA wiring from the battery to the top of the fuel pump lid connector, there is still the standard wiring from the lid down to the actual fuel pump.
This standard wiring is still your weak point. I would have thought that if you are going to a rewire with thicker gauge wiring, you have to go the whole hog and replace ALL the wiring right down the the pump itself!
Yep needs to be tested underload, I was able to see mine drop at idle and rev's. So an intank lift pump to an external pump is too much draw on the std r32 wiring.
The R33's may not see the voltage drop as much as an R32 as their battery is in the boot.
I saw such a voltage drop as I run the standard intank pump and an external bosh. So 2 pumps drawing through the small wiring.
Mearcat,
wiring resistance over distance. :laugh:
  • 1 month later...
I just wired up a relay this afternoon and all was going fine untill i turned the car off, now the turbo timer will not keep the car running but the ignition stays on but the car just stops. If i put the wires back to standard its fine, i tried using another relay but get the same result.
Everything was wired up right
30. 12v battery fused
85. earth
86. fuel pump trigger
87. fuel pump
Any ideas on what could be going wrong?
Does anyone know where the factory pump relay is.
Thanks.
85. earth
87. fuel pump
Thanks.
where did you get your trigger power feed for the relay from?
it will have to be from something that is retaining power once the turbo timer is activated and running.
factory pump relay for the R33 is in the boot next to battery
Did you use looms earth on the relay? You need to use both the looms trigger (obviously) and the looms earth.
I had issues with the fuel pump staying on when I earthed the relay to the chassis.
Ok ill try that first thing tomorrow, i just earthed the relay straight to the body.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
