can someone post a pic of the starter motor location?
i want to check its connection...
i recently has a walbro pump installed, and when i turn the ignition during prime sometimes i get nothing for a couple of seconds before it turno over
but once prime has finished it cranks straight away..
then again, sometimes it cranks fine!
only happened post-install of walbro by worksho[
cheers,
Warren
Sounds like bad connections some where.
There is no way a small motor like a fuel pump is going to bother a starter motor. If anything at all the starter motor would take the power away from the fuel pump due to the starter having a lower winding resistance than the fuel pump.
  • 1 month later...
After all the talk of upgrading the wiring to use the std wiring to power the relay and wire the battery directly to the pump... Has anyone ever considered that even if you use big 8GA wiring from the battery to the top of the fuel pump lid connector, there is still the standard wiring from the lid down to the actual fuel pump.
This standard wiring is still your weak point. I would have thought that if you are going to a rewire with thicker gauge wiring, you have to go the whole hog and replace ALL the wiring right down the the pump itself!
Yep needs to be tested underload, I was able to see mine drop at idle and rev's. So an intank lift pump to an external pump is too much draw on the std r32 wiring.
The R33's may not see the voltage drop as much as an R32 as their battery is in the boot.
I saw such a voltage drop as I run the standard intank pump and an external bosh. So 2 pumps drawing through the small wiring.
Mearcat,
wiring resistance over distance. :laugh:
  • 1 month later...
I just wired up a relay this afternoon and all was going fine untill i turned the car off, now the turbo timer will not keep the car running but the ignition stays on but the car just stops. If i put the wires back to standard its fine, i tried using another relay but get the same result.
Everything was wired up right
30. 12v battery fused
85. earth
86. fuel pump trigger
87. fuel pump
Any ideas on what could be going wrong?
Does anyone know where the factory pump relay is.
Thanks.
85. earth
87. fuel pump
Thanks.
where did you get your trigger power feed for the relay from?
it will have to be from something that is retaining power once the turbo timer is activated and running.
factory pump relay for the R33 is in the boot next to battery
Did you use looms earth on the relay? You need to use both the looms trigger (obviously) and the looms earth.
I had issues with the fuel pump staying on when I earthed the relay to the chassis.
Ok ill try that first thing tomorrow, i just earthed the relay straight to the body.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
