I never measured it but you could use a fuse closer to the current draw of your pump. You got me interested so threw the clamp on to my car just then, 9.4A continuous didn't seem to change at all. Driving a bosch 044 intank. I dare say that a stock pump or gtr pump wouldn't use that much, throw a 15A fuse on there, the wiring will definitely handle greater than than the current required to pop a 15A fuse. Measure yours if you want, I don't have any others to compare against.
  • 2 months later...
  • 2 months later...
040 in ur 33 will b no problem
mines been in my car for 8-10 months now and never had any problems...
Yer, so will rewiring the fuel pump be necessary as it is in an r32? Will the same process be used to do so? I went out and bought all the wiring already...
  • 1 month later...
Hey guys, I did this last friday, actually in the exact same way like gumflappers' wiring diagram.
I'm currently running a stock pump, but it feels like it's running smoother through gears, turbo seems to spool a bit better... so my 'gut dyno' says it was worth effort.
But now my fuel warning light stays on all the time... haven't tried to reset the ECU, but I don't think that'll solve the problem.
Anyone who has come across this problem?
Taking the bulb out is no solution haha :P
If somebody could help me out on this one, please do :)
I opened up the fuel pump wiring assembly or whatever you'd like to call it, looked at the pins, but it looks fine, and should make contact (just like it did before I started out modding it)... the pins are locked firmly in the plug, as they were before I even touched them.
This is how I did the wiring;
(I took the relay from the diagram by 'gumflapper').
I first depinned both ground and '12v' feed wire from the plug, then cut off the stock wires from the pins, and soldered the new thicker wire to the pins... the two pins fit well inside the plug and are not loose or something like that.
To get rid of the fuel-light coming on in my gauge cluster, I also tried to get the ground for the pump from the original loom, so the diagram looks a bit like this;
It still had that friggin' light in the gauge cluster :/
I then put it back to the first situation, and took the ground wire from the battery of for about 10-15 minutes, pushed the brake pedal a couple of times, doors open with dome light 'on', etc.
Still has the light coming on :)
What seems weird to me, is that when I meassured the voltage at the three-pin plug, I read a higher voltage when using the ground from the stock pump loom, than when I used a ground from a bolt in the chassis.
What am I doing wrong in all this?
Also, anybody who knows what the two-pin plug is for?
I don't read any voltage from both, with ignition switched on and off, and using the chassis as well as the stock loom for ground.
There's nothing about this in the service manual (that, or I just didn't find it).
Edited by stefan-w
hey
your much better off grounding the pump either to the battery directly or close to it. gounding it thru the wiring lume will reduce the voltage that the pump recieves therefore defeating the purpose of this mod.
in the photo above, you can see the 6mm brown and blue wires that feed the fuel pump. i would be checking the other smaller wires in the tank. i assume (never checked them myself) that they are from the low-level sensor. make sure all of ur wiring is correct and secured/soldered properly and check that all the plugs/sockets are locked together firmly.
however upon looking at that image there seems to be a few more wires in the tank (bottom rhc)... any ideas on what they could be?
I've got ground directly from the battery, just like the 12v feed... it's exactly as in the diagram you made :banana:
Only I used black and red wiring haha, the loom only powers the relay.
That second diagram I've posted was a try, to see if that would solve the problem (wich it didn't, so I went back to your wiring diagram).
Only now do I see you've pulled but wires to the pump, not just to the plug on top of the tank (wich I did)... this shouldn't make a difference I hope?
I'll do so when upgrading the pump, but not on the stock one.
Is that unprotected wiring and an open plug floating around in your fuel tank? :dry:
Are you sure that's entirely save?
i thought the same thing when i took out the stock pump (WTF r all those wires floating around in my fuel? :S) i decided not 2 fix what didnt seem broken... lol
"Only now do I see you've pulled but wires to the pump" i dont understand :S
Crap... 'typo', and I should have written it a bit more clear :rant:
What I meant; I only replaced the wiring up to the female connector (wich goes on top of the fuel tank).
I noticed just then that you have also replaced the thin stock wiring from the male connector to the pump itself, inside the fuel tank... obviously, I did not.
I don't think that'll cause my light to come on though, but I'm no expert.
replacing the wiring to the fuel pump inside of the tank itself will have nothing to do with the low-level sensor... 2 b honest i could not tell you what the sensor even looks like as ive never pulled it out. i had enuf trouble getting the fuel pump in and out let alone the low-level sensor.
  • 3 months later...
pidibump!!
I read the whole 12 page thread. Most people talk about r33 or 32 gts or 32 with Aftermarket pump.
What about Stock fuel pump on a GTR 32 with something like 350whp.
Any benefit?
Maybe, that this help you out:
http://www.stealth316.com/2-fuelpumpguide.htm
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
