Has anyone done the re-wire on a Ceffy?
I've followed the first post and tried a few other variations with no luck... All I can do is get the fuel pump to run constantly off the battery not accessory/ignition (ie pump running whilst the car is off)???
I didnt go quite to the extreme as the OP.
Mine just stopped working one day. No idea why. Pump relay and pump were both getting voltage, but nothing was working.
All i did was disconnect the stock 12v feed to te relay, then take the 12v feed from the 4ws Motor and connected that up instead seeing as the 4ws isnt used. . Tadaaa. Perfect running now. Uses the stock relay and earths. One wire to change.
  • 4 months later...
hey guys, im doing this mod atm, and ive been wondering wether this would work or not.
im running a dual stage boost controller off a switch in my dash. im wondering if i run the battery 12v feed to my relay, and then run a positive feed from my dual stage switch to make the relay switch on and off, and then tap the battery 12v feed from the relay into the std pump positive feed would this cause any issues?
doing it that way, i can still run the reduced voltage when im just cruising around the streets on low boost, and if i want to give it a boot full and switch over to high boost(low boost is only 10 psi so the pump will suffice without the extra volts) it will pump the extra voltage from the direct feed into my fuel pump to get the max out of it. this in theory should work, but what im worried about is the extra voltage running back up the line on the stock wiring to the stock relay and causing a problem. it would have been good to beable to shut off the stock pump wiring altogether, but the issue there is when the lines switch there will be a momontary lapse in power to the pump.
is it worth a try or should i just run it at max all the time?
Edited by OMY31T
  • 1 month later...
i guess u could try that if u really wanted to but whatever fuel the engine does not consume gets fed back into the tank anyways... id rather have more fuel then not enough when i "need" it...
  • 2 months later...
Did this mod yesturday, Have some photos and a diagram if anyones confused to show how I did mine, seems to have improved the car a bit
Relay mounted:
Wires spliced into pump wiring:
So you don't need to take the pump back out and replace that wiring also? I really don't want to do that if i don't need to
It would be better to re-do all the wiring, but I didnt want to pull the pump out and play around with the plug in the fuel tank cap etc so I just did it like this
The pump sounds louder so must be getting some extra voltage, no problems so far
Cheers mate will do your way and if i have issues rewire as necessary. Not pushing the pump that hard (similar power to what you have
hi newbie here from UK
r32 gtr owner.
could someone tell me what do you do with the old fuel pump plug??
i realise i can either cut for 12v before the plug, or fit a male spade fitting inside the plug on the 12v side to trigger the relay.
what do you do with the plugs negative feed?? simply cover it up with tape?? or does this still need to go to ground also?? (so in total, 3 wires to ground, plug/relay/pump)
thanks
ps, anyone confirm the wire colours for the + and - on the plug on a r32 gtr
  • 4 weeks later...
  • 3 months later...
Did you use the negative (gray) from the wiring loom as well or just the 12v blue?
Cheers
  • 3 weeks later...
Also my battery in the boot on the drivers side so all my new fuel pump cables are short in length, I'm running a walbro e85 400lph pump
What would be the best size cable to support this pump? 8gauge would be hugely overkill for such short distances?
i used 8g as i had few meters of spare cable, also make sure +ve and -ve are the same gauge, my one just plugs into the existing pin, wires inside the tank hasn't been touched
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
