was just seeing all the threads on different gloveboxes - i just assumed they were all the same... and mine seems different again to all the other descriptions - mine opens from BOTH sides and is full depth for CDs etc... most other people whos open both sides seem to have posted that they are very shallow... weird so many different ones!
And yeah - factory Xenons with height adjustment for the high beam, controlled by a thumb-wheel on the dash to raise or lower the pitch down the road.
Edited by Brazen
I would have thought this test (fanging on a dirt road) ineffective because of awd?
hmm, you should still be able to tell - if you can't what is the point of having one! :P I haven't been on a dirt rd in my stagea yet (it does have the lsd as it is a four S), so can't comment from experience..
Ian
Wow that is cool!!!
My centre console storage space is NO WHERE NEAR that deep, and mine only opens from the front, it is hinged at the back, so it opens up like my old r33 did.
I never knew you could get it to open up from either side, cool!
I'll take some pics of mine on the weekend :P
Thanks Nick!!
Sorry pics took so long, but as promised here it is :w00t:
As you can see it is only like 2 inches deep, but when you reomve it to see what is underneath, it has this MASSIVE airbag thingy box directly underneath it, dunno wether that is where is is on stock cars though....?
It's a big silver box with cuation airbag stickers all over it and heaps of wires running from it towards the front of the car, looks like it belongs there as all the mounts for it are there and it actually sits raised about 1cm off the floor pan.
I'll take some pics when I can, dont hold your breath though :(
Owned :(
Airbag thingy? Is it an airbag or what? If it is, how the hell did they do that converting to manual
It is the g-force switch(if you call it that?) that sets the air bags off in your dashboard and steering wheel
Basically when you have a accident, the switch makes contact inside from the force of the impact and off go the airbags
I'll take some pics when I can, dont hold your breath though :P
It's most likely the computer with the g-sensors, as Darrin has mentioned. Don't forget, also, that GT-Rs (and probably GTS4s) had the g-sensors under the centre glovebox, behind the handbrake, and this was used as part of the triggering functions of the ATESSA computers. Seeing as most of us have RS-Fours, then they should all have them there, whether stock or converted to manual like mine and Ska's. I haven't bothered (or had the need) to take that part of the centre console off, so I can only assume they'd be in the same spot.
Who knows, maybe the same g-sensors were used for the airbags and the ATESSA!?!?
  • 2 months later...
  • 1 month later...
hey, i tried that, and i got pinged with a $99 parking in loading zone fine, they didn't believe i was on business, which i was... lowsy parking guys
A bit OT, but since when in NSW does it matter if your private rego'd or business.
It is my understanding that any wagon, ute, van or larger LR/MR/HR vehicle can legally park in a loading zone.
Alright, ignore what I said inpost #54, the airbag computer and ATTESSA sensor are separate items...
Airbag ECU:
Airbag ECU (bottom of shot) and ATTESSA sensor (top of shot) with whole console removed:
ATTESSA sensor just behind the gear shifter:
  • 1 month later...
I would like to add a link to this thread in the "Stagea Diy's, How To's, & Fyi's" thread here:
http://www.skylinesaustralia.com/forums/in...howtopic=102808
And then unsticky this thread, any objections?
I think this is one thread we should leave exactly as it is now, we still have a lot of people visiting this part of the forums asking questions, and having it kinda hidden away makes it harder for those who are new to Stageas and are thinking of making a purchase or doing extra research.
I think the DIY section is better for us who already own them, and know to use it as a reference point when looking for instructions, etc. when we're doing repairs and/or upgrades. For any of those types of threads, then they could be put in the one DIY section...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
