just looking for some info on the falken RX 04V (i think thats the code..maybe RX 042V, RX 04V2??) they are supposedly a sort-of-semi slicker, looks like a street tyre with fat chunky tread blocks, not like a RT 215 or RE55s bridgy.
i can pick up set for a good price but i cant even find anything via google on these tyres! nothing on the falkentire web site either...
any help would be great!
https://www.sau.com.au/forums/topic/92198-falken-rx-semi-like-tyre/
OOh i found something, but its not really any good to me. At least i can confirm the model number "RX-04V"
FALKEN RX-04V Sタイヤ 245-45-17(2本)
How can this tire be so hard to find details on!? Dont suppose anyones used or using them???
These ones right?
They are good I have used them once, got them for $220ea in 245/45/17 from Tempe Tyres
Definately better than any street tyre, but not among the best semis. If you want great but not best performance at a brilliant price grab em :D
no thats not them! They dont have a semi slick look at all, they just look like a road tire with chunky tread blocks. I think ill just buy em and try em!
The words "chunky tread blocks" should ring alarm bells.
The RX series of Falken Azenis are rally tyres (which also matches your description). Whoever told you that they're "some sort of semi slick" either misheard someone else talking about them being a type of Falken competition tyre, or trying to offload them after buying a whole bunch thinking they were RS or RT series tyres.
Are you building an R33 offroad rally car? If not, tyres you steal from a taxi will probably do a better job of providing you with traction than these things on sealed roads.
Here's Falken's actual motorsport range.
As you can see, the RX-04 series are winter rally tyres, which means that not only will they not grip very well on the tarmac, but they'll also overheat within minutes of light use.
You can buy and try, but I get the feeling if you're making 265rwkW that you're going to conclude your rhyme with "die".
The falkentire.com web site is the American site, and its pretty much useless for competition tyres. They only list Falken's street tyres, with the RT215 / RT615 being the pinnacle.
Edited by scathing
These ones right?
i take it they arent 'road legal' tyres?
and are these the ones you mean, SLY33?
Azenis RS-VII
Azenis RS-VII
thats like what im talking about! im fairly sure the model number is different tho, but ill post em up when i get them. So go blow your snow tyres out your asses guys ;) hehe
LOL
PROBLEM SLOVED! now i feel better :D
As mitchy suggested the tyres i was asking about are in fact AZENIS RS-VII's.
The reason why i couldnt find any info on them is because these particular tyres are coded RX-04V, as i orginally posted. The reason for this is that these tyres are coded specifically for Australia and Canada, hence not bearing the RS-VII code as it would in Japan.
Definitly NOT snow tyres!!! so i wont be needing those snow chains sewid. :P:) lol
I thought it was iffy at first with the model number situation, but as you can see, they are identical to the RS-VII's.
see? like a street tyre but with chunky tread blocks! :D
by the way, the compound is very soft, even when compared to my medium compound RE55s, also the sidewall stiffness doesnt seem as stiff as the RE55s, so im expecting some decent straight line traction! I only plan to run them on the back, as on the street the RE's warm up slowly and cool down quickly. A friend whos running these on the street says they hook up crazy. Ill post up a review when i get them on.
Edited by SLY33
Yeah I've used these ones too, have you already got them? I think you will find these are actually a wet compound tyre and they don't take a hard time too well.
Ie Fatz and I wore them down to the canvas in 3 days of light competition.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
