bov's arent allowed to vent atmospherically, full stop.
legally, they have to be 100% plumbed back.
edit: even if the pod is secured, its still good to get a permit, there are some wanker police out there that stop at nothing short of a permit.
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1664478
was funny.. i got pulled over today whilst driving my housemates wrx.
officer asked me to pop the bonnet, so i did. he then started pointing at items asking me what they were, i just claimed it wasnt my car, and i didnt know anything about cars. worked a treat ;)
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1667666
LoL! That's an idea! I was gunned at 59km/hr on a 50km/hr road. And frankly, i didn't know it was 50 on all roads. And i just got my car and all. So i told the copper that i didn't know anything, i just got my car. Worked like a charm too. I think the fact that i havn't converted my liscense is another contributing factor. =D
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1667728
I have a Greddy atmo BOV and got a permit for it no problem.
The cops are supposed to ask if you have permits for the mods they are pointing out. If you have permits they are supposed to accept them and let you be. If they are having a shit day like Strich9 says, they give you a yellow, and you have to pay to take it over the pits to show them that you have permits for it in the first place. The whole system stinks!!!!
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1674873
I've got permits for my BOV HKS SQV, Pod filter, etc.
How did you get permits for the HKS BOV? I got the HKS SSQV one, and im sure you cant plumb it back. So how did you get the permits for yours?
I got told that you put a ball bearing in the vacuum hose coming off the top of any BOV when your in the pits, and it wont make any noise, so they can't get you!!!
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1678269
Plumb-back BOV's are legal and require no permits as they meet ADR's and are supplied stock on most turbo model cars.
Atmospheric BOV's apparently dont meet ADR's I hear they fail because they fall under being a nuisence and distraction to other drivers.. Not really sure on how truthful it is but even with permits you can still be slapped with a yellow for atmo BOV's
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1681116
i guess its just luck on what cop ya get and wether he got laid the night before... if ya just ploddin around and dont be a smart ass i find cops to be alrite, i even had a cop check out my in dash tv :) ... but if ya up and down the gears bein a tollie then they might get a pit picky.. no cops are the same and all i get pulled over for is breath tests or licence checks, just be polite and they might not hit ya up with, just pop the bonnet mate hahaha ..touch wood
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1682719
I thought that the SSQV is full plumb back system? there's that thin tube going back into the engine thingy?
yah I did that ball bearing thingy while going through the pit...there is a thin hose going into the SSQV remove that and shove sumthing to block the air flow...and tadaaa no sound at all...but really use up a lot and a lot of fuel...
https://www.sau.com.au/forums/topic/92316-bovs/#findComment-1703730
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
