2 Weekends ago, i blew my exhurst to turbo manifold gasket. when i had a look the 2 nuts on the right of the turbo were loose, so i know how the gasket went.
I rang a parts supplier and they didnt stock the gasket so my boss just told me to make one, since he already had exhurst manifold paper. Should i have used gasket gue or something like that?
got it all fixed up on wednesday, and by saturday it was gone again. just wondering if normal exhurst paper would be ok on my R33.
yesterday i just drove around to an exhurst place to see if they had a proper gasket and they didnt so i asked him for a quote, he said that the exhurst manifold would prob be warped. so it would all need to be machined... does that sound rite?
Thanks in advance
Wayne
https://www.sau.com.au/forums/topic/92431-exhurst-manifold-to-turbo-gasket/
Get the proper gasket. Should fix the problem. You can't use cheap crap here, just won't work.
It is possible to warp it but I don't think this has happened in your situation.
Sealent will not help much - too hot - even more reason to get the proper gasket.
As long as it's a quality item and not that cheap stuff.
I wouldn't say the gcg ones looked that good... about 1/3 the thickness of the genuine nissan copper ones. Its almost paper thin.
I bought one and never bothered using it when I compared it to the proper nissan one... even if it was 100k old..
Always thought that GCG produced good products, but maybe not in this case.
Play it safe - go the Nissan. ;)
Not complicated to install, just put in place and bolt her up.
Maybe some lock tight on the nuts so they don't come loose.
Edited by WetGTR
Heres a trick, get some proper exhaust lock nuts. If the ones on there are coming loose, then they are not doing their job.
I reused my old genuine gasket, the steel folded one that came of the factory mani. More times then not ive found that the nuts are incorrect and if it comes even slightly loose the gasket has no chance.
Is it an a/m mani?
i had the same problem. i bought a gasket from hardcore then realised it was much thinner than the nissan item so returned it and got 1 from nissan. from memory it was under $40. Didn't change nuts...just bolted up as tight as possible and hammered the brackets as close as possible to the nuts. I hope it lasts as it was a hassle to change.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
