with a question like that, you're not even going to be considered :P
Listen, you're the one who's asking for a favour. As mentioned above, this is a public forum. People can say whatever they like. They aren't even serious anyway, they're just mucking around. Ever heard of the saying Beggars can't be choosers? YOU ARE THE BEGGAR.
Think about it like this. How does it benefit people to drive almost all the way to the border of civilisation to give you a lift? They get nothing out of it. Yet some people have offered, as THEY ARE NICE.
so quit your whining and be thankful that people ahve actually offered you a lift!
  • Replies 49
Posted Images
If theres a few cars going along I'll come 2. I only live about 10 minutes from there. Are there any 16 year olds? :blink: hahaha
I thought that was heaps funny. Especially as you have the fonz as your avatar.
Sounded like it came straight outta his mouth.
  • 9 months later...
Hey...
I've been reading up on formal runs n i too would be intrested in someone taking me n my mrs to my formal...
This goes out to the people who live in the sydney suburban area. Just intrested on type's of cars n prices... Formal will be held in Homebush!
Hey...
old thread.
but yes people on here will help out just start a new topic.
15 = JAIL BAIT!
check date
:P
has anyone been around a 15yo lately? annoying yapping little terriers. lol.
can i please, please, please, not be involved. kthnx.
check date
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
