Hey,
Anyone got pics of Nigels Patrol? And what psi has he running on this dyno? Almost 200rwkw sounds good for turbocharged 4.2 litre engine!
Cheers
Grant
  • Replies 97
mine had the screamer .. Nates was the 4dr with white rims...
i honestly didnt think my car was that loud till i hear it from the outside
sorta happy with the end result 124.9rwkw .. in shootout mode. seeing its just turned over 202000kms.
was a great day. nice to meet some new ppl with the same passion modified cars.....
Bit worried when the cops rocked up. lol
Matt
... and I'm spent.
If you want a high res, PM me with the filename(s)
Was a great day, had lots of fun. Good meeting some more people off SAU.
That patrol was f**king nuts.
I must have missed Denhams run, was that before people arrived, or after the AFAS XR6?
I wasent going to run as i have a stuffed external gate flange but then when the xr6 pulled out over 300rwkw I went on and turned the boost upto 21psi to try beat him and hoped the flange would hold for 1 run, but it didnt and started blowing exhaust gas out the engine, hence the low 245rwkw reading!!
Nice work guys!
What did the Gem get?
Gem got 55rwkw. Preety good for the old gem as I seen a new proton get only 30rwkw.
Just had a look how much damage i caused yesterday to the external gate flange on the manifold and the gasket is in pieces and 1 nut and part of the bolt have been sheared off!! :(
Have to pull turbo off and cooling lines to fix it properly this time
Shit not good new inasnt ... hopefully u will be up for the next dyno day to put that xr6t in its place, unless its got more power again ?
Sounds like was a good day, not bad weather wise either :(
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
