13.4 second 1/4 for your 'stockish' R33. (A how to guide).
the 255's let down to allow side wall flex would do the 225's in over the 60ft. If we are talking the same rubber compound/tyre.
The inflation of 36psi will put the 255s at some disadvantage Vs 15psi. Then again 15psi might be too low if you are talking street tyres (not nitto's or mt's).
Guest MFX_R33
If the tyres are the same rubber/compound, then the tyres with less pressure will give you the most traction. Width of tyres does make a difference but not as much as pressure. A 355 trye at 30psi has the same contact area on the tarmac as a 195 tyre at 30psi. The contact area is determined by the weight on the tyre and it's pressure. So with the 16"s there is more sidewall to flex, given that the compund is the same over the 2, I think the 225 on 15psi qould be your better bet.
Jeff.
Atmospheric BOV`s might help more air to pass, but, having an Air Flow meter equipped car you confuse the ECU and undo any bennifits you could achieve.
I would recommend using a GREDDY plum back style, Which flows 2-3 times the air. It might not sound as good as the standard , but, the truth of the matter is the more restrictive your BOV is the louder it is.
Or you can get away with an atmospheric type when using a S-AFC as this is equipped with a function that momentarily sends a preset A/F meter signal to the ECU when the BOV is venting. No more kneecapping flames !
Agreements - Disagreements ?
boostd,
I'm not a fan of the aftermarket BOV on a stock turbo. Experience shows me they are often a step backwards in performance.
It is a superficial mod. It is totally unnecessary in the pursuit of a 13.4 second 1/4mile.
Flywheel questions
After the new flywheel went in did you notice an increase in fuel consumption? Also when crusing around town does the car tend to slow down more quickly when you back off the accelerator (ie feels like your towing a small trailer up a hill)?
I can see how a light weight flywheel would make the car go faster but how practical is it to do for a daily driver??
Originally posted by riggaP
Flywheel questions
If you have this problem make sure you get a full exhaust system, deffinetly makes it a smoother ride (also better midrange power).
Benm: Dude wat are u talkin about. This has nothin to do with exhausts, the fact that he has a lightened flywheel means the car will rev quicker hence will also drop revs quicker aswell. It may give the feelin that the car is slowing quicker to some.
As i said, with a full exhaust system the engine will breath easier and wont 'slow down' as much when off the accelerator, its 1 of the first things i noticed when swapping my stock dump/front pipe to a 3" custom.
the lightened flywheel will decrease the time it takes for the engine to speed up or slow down (to a far lesser degree).
I have one of the lightest flywheels around @4.8kg and it's nothing but a pleasure to drive in traffic. My entire car is based on being 'comfortable' over long distances and in heavy traffic for long periods.
Many a slow-ass-know-little will tell you that the lightened flywheel is this or that and poo poo. Kick them in the head and move on, if it's your friend then kick them softly in the head.
lol. This was actually a guy who claimed to be a race mechanic at an autobarn store?? Some of the stuff he said made sense.... but he denied the existance of the boost solenoid on R33s tho, said something about the second cam kicking in at 4700.
nigasnt
Yeah i know... he also said something about his uncle being on the 32GTR bathurst team??? Thats when he lost me.
Altho some of the stuff he was saying made heaps of sense... prolly coz i aint know shite...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
