2.  It is going to weigh more in the exact location that GT-R's don't need more weight.
3.  It is going to take longer for the car to get up to working temperature - more engine wear.
I didnt notice a "great" difference in weight at all to be honest.
My one (as stated earlier) is quite light indeed.
Also, depends on your mannerism, i always warm the car up for a good 4-5 mins before going anywhere. So that can be a mute disadvantage depending on the person
  • Replies 42
Posted Images
air flow becomes a problem
that's the primary problem... plus oil coolers, intercoolers etc etc hanging out the front of the car.
Off topic, but I really want to run an oil cooler to the rear, in front of the diff, but worried about pressure drop back there
i have a PWR one in my GTSt, does a great job, i was thinking maybe go a jap one in the GTR as i thought it might be better than a pwr? Can anyone tell me what makes the PWR ones special? i was told by an ARE guy that theirs are better (biased obviously) and that they use a dual pass horizontal flow setup, and vastly improves cooling. Apparently the pwr ones run hot on one side, whilst the other side is cooled more. Can anyone elaborate on this?
bah, its all crap IMO RE: PWR (or race radiators)
People say that cause they are cheaper. One thing, they can be cheap and still be great, as i said, $660... bolt in... even cheaper than the $800 and will do as good of a job.
  • 3 weeks later...
the horizontal pass radiators are better at cooling due to them forcing the water through to get cooled twice.. goes in the top runs right accross the radiator then falls down then runs back accross the radiator to the water pump pickup...
sad attempt of a diagram of the twin pass radiators attached ..
horizontal flow radiators do cool better.. but really when you think of it.. i'd rather keep the factory one for street use.. most of the cores in all the alloy radiators tend to be the same design with the tubes as each other.. (i work in radiator shop sadly(might not be for much longer(shitwork))) so yer if your having over heating problems think about it it might not be your radiator.. could be your thermostat or clutch fan
if your after bling and do some track work than yer go ahead get an thick alloy one for general street use a standard one is more than ample except for when you've got one hell of a thick intercooler sittin in front which the air is struggling to flow thru that let alone your condensor than radiator
  • 1 year later...
Sorry for bringing up an old topic,
I basically pull my radiator out and have it service every start of summer, i'm about to drop mine off for a Radiator place to have it clean.
Today i stumbled accross Jus Jap site and saw their Alloy Radiator for R32gtr with Shrould still in place and only cost $399. I was thinking if i should spend $100 to get my stock radiator service or spend that extra $300 and get a fully sick Alloy one?
Has anyone ever use JusJap one? What's your feed back?
(Note, my stock radiator perform WELL, constant 80degree, raise around 7,8 degrees only because i was stuck in traffic for over 10 mins on a 40+ degree Melb summer)
Is that the cooling pro ones?
I got one of them last year with the top and bottom hoses to match. No probs with old radiator but for track and drag i will help in the long run.
http://www.skylinesaustralia.com/forums/in...howtopic=117584
Thickness of top tank is 40mm, radiator width is a little less if I remember correctly. Shroud did not fit back onto mine :pirate:
Yes that was it.
So shroud could not come back? They claim that it can retain the shroud.
Also did you notice any different in temputure wise?
Cheers
Just got my CoolingPro from justjap installed, $400. Very hot, very humid day today on the gc, let it idle for 30 mins and didn't get over 86C, then immediately thrashed it and the temp didn't budge, drove it home this arvo, still quite hot and it sat on 80C even after i went up a long hill in 5th winding up to 11psi for 10 secs (2500-3500rpm). Oh, and this is all without the shroud for now (need a 33 one). Can't see any reason why it won't fit although the fan is fairly close. But then again I have a 33 one modified to fit in my HR31 with custom brackets... so it's not exactly your regular application.
Comparing to a PWR, the core looks exactly the same, it doesn't seem to be baffled, but for the performance i'm getting so far on the hottest day this summer, the price is right. :( I know mid 80C doesn't sound great, but you obviously don't want your car running cold, and the thermo only starts to open at 78, so really it's about stability. Idealy you want something that stays below 90C under any conditions. It's looking like I just got that for $400.
Edited by aDrew_C
With the radiator I added a Nismo 62 degree thermostat and radiator cap as well. Temps are never above nominal half way point on the guage.
The end parts of my shroud would bend and then the screw holes would not match up so I left if off.
The top hose from JJR was also a bit too long so I had to cut about an inch off to get it to fit.
Maybe you should leave the shroud on so air can concentrate into the block instead of divert out everywhere!
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
