Hey dude have you got your car working properly again?
all the probs you mention i pretty much had the same trouble. couldnt work out what it was to begin with, took her down to my mechanic (i have two!!) - who deals with performance cars all the time and he went through every possiblity of what could be going wrong, wiring, ecu , sparkies................coilpack....showing a greater heat resistance than the others.
and then about a couple of months later another one dropped on me....i knew exaclty what it was, cause it was doing exactly what happenend last time = not paying another 195 bucks for a coilpack - SPLITFIRES! a skyline's best friend!!!! no drama since.
i had lost 3 coilpacks in 6 months. :cool:
My r34 gt got the same problem. Last time when i had it checked at the mechanic (some imports experts as they said), they told me my car had ECU problem after check it with their computer (they said drive strain problems, I think) and change the spark plugs. Since it's a tiptronic non-turbo, they told me it is nearly impossible to find new ECU or aftermarket ones. They told me I have to find a half cuts or just take out the engine check light and sell it. By the way, anyone knows any trust worthy mechanics around Melbourne that can handle this job? I very appreciate if anyone let me know so I can fix my car instead of selling it. This problem is killing me for months.
Its most probably coils mate as every nissan owner goes through. (seems to happen in R34's more though) The mechanic doesnt know shite and sounds dodgy to me with his solution to your problem. READ- Never go there again!
Take it to another mechanic get them to read the error code your car is coming up with and fix the problem. If its making all the same symptoms as been stated here its almost 100% coilpacks. $650 later and your new splitfires will have solved the problem.
  • Like 1
PM sent...
i would be defintelty going and getting you car hooked up to a diagnostics computer.....this will bring up error codes. every time your engine light comes up the ecu will record the error code in its little memory thingo. when you hook it up it will come up with the code itself, and when the last time the engine light came on.
but seriously get those splitfires. saves a lot of $$$$ in the end :D
like i said before i lost 3 in 6 months. and at nearly $200 each, its so much cheaper in the long run,
when i out mine in the car ran a little too rich for a little while, but i think that was more or less that car going "OMFG!!!!!!!! these feel good!!!"" (i gained 7 kW out of them :( ) but all good now!!!!!!!!!!!!!
  • 9 months later...
lol i get the same problem!!! i thought it was my catalytic converter coz everytime i got the symbol, my car shudders, and the exhaust sounds hideous for a while before it gets back to normal. also, i hear a rattling/tinny sound which i believe has somethin to do with some part of the exhaust (cat). gonna take it to mechanic on monday and i'll let you all know what i find out lol.
bump
My 34 she is have a hard time to as soon as it shows up it just sounds all so shitting the idle all messed up. can i still drive it or do i take it in to look at right away?
with out driving her...
OK, So I drove mine last night and no issue for the first 2 drives. But after 15min on my last drive, it came up. This time the symbol came up when I gave it gas after stopping at a red light... and then I let go of the accelerator, it sounded shit for 2 seconds, then I gave it gas again and then it sounded fine... but the symbol remained
Bloody annoying
It's a simple fact, you buy an R34, you need to buy splitifres to never have this problem crop up. I'd say over 50% of R34's have this issue. It was so annoying the second I bought my second R34 I just changed them so I'd never get the problem in the first place.
Also LOL @ the mechanic mentioned above, the amount of times I've seen them say "get a new ECU" as they don't know dick about R34's
just double checking with you guys, before i get some splitfires, its the SF-DIS-008 model right? for R34 n/a sedans with rb25de?
also, where can buy them in SYDNEY (ive seen nengun.com sell it for around 500 dollars... but they don't do installation... anyone noe how much it mite cost to install?... and where?)
THANKS
Edited by CDA
THANKS
http://www.skylinesaustralia.com/forums/Di...ks-t192015.html
^^^very good step by step guide link to doin it yourself and save yoursefla few $$
also since i had the same problem as you i changed my coilpacks along with my new park plugs and the car's fine now :glare: also bought my coilpacks off ebay. ($500)
cheers
Edited by Alex G
Croydon racing developments have em for $495 and they charge $95 for installation... I'm just REALLY WORRIED becoz its a lot of money to be spending and... what if it doesn't solve the problem... :ermm:
OH MY GOD LOL
I got the dudes at CRD to run a diagnostics check on my ECU, and they found that it was indeed an ignition problem. They said it was either the coil packs or something called the "crank angle sensor". I couldn't be happier, I can actually FEEL the difference with the splitfires, the whole car just seems so much more vigorous!!!! lol!
ONE PROBLEM HOWEVER: they quoted me 495 + 95 labour for the splitfires, but they assumed that the RB25DE was in a similar configuration to the RB25DET, it turns out though that the N/A engine has TWO THROTTLE BODIES - WTFWTFWTF WHO KNEW THIS - compared to the Turbo which has only one, and this made the whole process twice as long, they took two hours to do it instead of 1, and had to charge me extra for the labour, and coz i got them to run the diagnostics check as well, it totalled to something around $730!!! - But I tell ya what, its SOO worth it.
SplitFire Coil Packs SF-DIS-008 = $495
2 Hours labour + diagnostics check and ECU reset = $235
damn, not only R34 owners, but EVERYONE should buy a set of these.
p.s. i felt so ridiculous rocking up there with a 4-door N/A skyline, when all the other cars you see there are r32/33 GTR's and 200sx s15's fark....
when i was going to change mine i decided to get an expert to do it because you had to remove the exhaust manifold and heaps of other crap compared to the turbo ones. but he changed them and i bought new ngk iridium spark plugs as well to put in and it runs way better.
lol yeh they had almost my whole engine bay removed lol
Wow... you know you really have to be careful around some mechanics..
As soon as they figure out that you don't know much about cars they'll throw in a whole bunch of sh*t you don't need. They'll start throwing all this info and technical jargon at you to confuse you, then do some work take your money and say whoops wasn't that.. lets try again.. take more money.. and before you now it you've spent $2000 when you should've only spent $500...
You should look at really getting to know your car and it's components.. take the engine apart one weekend or when time permits. Read your car manual.
I'm not sure about the other skylines but the R34 has a fail-safe and backup for when the car sh*ts itself.
If any of the major parts of the Engine Control System fails ie. Any of the major sensors such as Engine coolant temp, mass air flow sensor etc. then the fail safe estimates the conditions the car is driven under and the back up regulates certain parts of the engine so that it can still be driven normally.
There's a useful table in your car manual (The Symptom Matrix Chart) which shows the relationship between the controls and the sensors/actuators so you can see what's actually causing the problems..
Or like MissR34 said.. get it hooked upto a diagnostics computer.. you can also trouble shoot it yourself if you have a CONSULT (a small blackberry palm pilot-looking device) .. and that will tell you what's going on. They come with a manual and you can test each part of the Engine Control and Emission System. It hooks up to a wire located on the driver's side.
Thats all I know really.. but yeh watch out for dodgey mechs...
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
