Problems solved. Use this thread as a reference if you have shaky a steering wheel!
Hi. just got my skyline gtst 2 weeks ago. After getting to know the car better now, I've found that my steering wheel wonders a little bit now and then (esp at slow speeds on pokey roads around Canberra). I've also noticed that the steering wheel shakes noticeably when doing about 100kph and or stopping really quickly (ie stomping on the brakes).
I have Ziex 326's on 18" rims. I read in some tyre threads that the Ziex are really bad and could be the cause of my problems. The suspension is completely stock, stock engine (cept the exhaust).
Are the tyres a likely culprit? I thought there had to be something seriously wrong (and there WAS, read on) with the suspension for the steering wheel to shake like that...
Edited by sl33py
https://www.sau.com.au/forums/topic/94003-wheel-shaking-and-tram-lining/
Check the front bushes, also check wheel balance and alignment if you dunno how then take it to a suspension specialist for a "free check"
Your wandering problem could be a simple case of "bump steer" the wider the tyre the more noticable it'll become, warn bushes will exagerate the problem.
Hi, the front bushes are brand new, they were replaced as part of the conditions of me buying the car cos the NRMA report said they were shot :D
Yeah the tramlining isn't tooo bad. It's more the shaking I was worried about, and then the fact that ppl said the 326's are rubbish and maybe i'll spin out when i could have better tyres and more grip.
hmm maybe not balenced properly my friend got some 18s on his r33 and and balence the rims and tyres but not with the spacers they had to put on to clear the brakes! And the steering wheel shook something special at 100km/h
  • 1 year later...
Haha just saw this again! Old thread, but still have the same problem. Thought I might update it in case one day someone suffers the same problems.
@ above: Nope, I don't have spacers.
Anyway, since posting here, I've had the wheels balanced and aligned about 5 or 6 times at various places. My rears were found to be both pointing to the right, so it was like having the back of a turned forklift on the car. I had a front camber kit (I think) fitted to help cancel some pulling to the left I had, because there was more camber on the RHS, meaning it was like I was on a permanent camber tilted to the left.
But I've still got the steering wheel shakes. At low speeds, It's a mere shiver, which has passed under the eye of many a "tyre guy" either unnoticed or "that's just the road mate". But sometimes (can't recreate the conditions reliably :P ), the steering wheel just shaking violently left and right, and it doesn't represent how rough the road is at the time. It sometimes does it badly on very flat freeway.
I took it to another place and they found that my car was on its front bumpstops. So I got new shocks, springs and bumpstops all round from SydneyKid's groupbuy (I kind of felt like an upgrade anyway, and didn't want the front and rear geometry messed up). So now it handles pretty darn nice on corners etc with not much roll at all now, but... it STILL shakes.
So we put it up on the rack and had a VERY good look at all the bushes. We found that the front steering rack mount bushes were shot. And also my rear cradles bushes are munted. Mechanic said he'd never seen them in this condition on just a 10yo car, usually on R32's, so he was pretty surprised. He found some more bushes he couldn't say for sure were fine. I've had this wheel shake problem for nigh on one year now, and it's really bugging me now, so I said "if in doubt, swap it out".
I don't have the list on me, so I might mess up some of the terms/names here, but basically we're changing every single bush in the suspension except for the ones at the top on the front (mechanic doesn't know of replacements you can get for them), and the ones which I think hold the rear steering rack where it joins to the wheel. I'm also getting a HICAS locker. Also getting adjustable rear camber rods. That's all ordered (one part apparently is made from scratch and takes 2 weeks) and it should be fitted within 3 weeks.
Mechanic said after this, there really isn't anything else that can be replaced, so I'm REALLY hoping this fixes the shaking. Sure, it handles nice overall at the moment, but when I feel like an old man cos of the shakes after driving, it's not much of a consolation :action-smiley-069: My mechanic said my car is still one of the smoothest he's driven (and he's had lines in HPI, so he's seen a fair few), but when I first bought this car, I could do 180kph and barely even feel any untoward shaking/shivering in the wheel compared to what I do now. I don't mind feeling the road (feedback) through the wheel, but it's gotta represent what's under me at the time, not crazy random shaking!
And I won't even go into how much all this troubleshooting has cost me, cos at this point it's just me VS the car until I get it sorted, I run out of money and go bankrupt, or I run out of patience and drive it off a cliff!
Will update this with developments as they happen. One day I'll get to power upgrades...
  • 1 month later...
Further Update: Steering wheel still trembling/shaking. Car's currently getting every possible bush in the suspension replaced (ignoring a few which are OK anyway, and replacements couldn't be sourced). Rear cradle bushes were shot. Front steering rackmount bushes were shot. Turns out one of the steering rack tie rods ends was munted, one was average, and the rack itself is bent. Hoping like h3ll this is the last of the problems because a) running out of time and patience, and b) mechanic says there's nothing left to change after this anyway!!!
Nope, no damage to the wheels. I've had the wheels/tyres of one of the workshop owner's on my car for a few days and the car was doing the same, only less intense because he has larger profile tyres, hence a little more give. And nope, no spacers.
When i bought my r34 gtt it had a brand new set of antyre tyres on it. Long story short, they were terrible.
Similar symptoms to what you describe, on the freeway i had a shake in the wheel anywhere over 100kph,
Grip in the wet was terrible and dangerous. ect ect,
I got a set of potenza adrenalin re001's. All the problems dissapeared and the grip levels are amazing in comparison.
It was the rack. It's all fixed now. After all the replaced parts, if I had to describe the car in one word, it would be: TIGHT. Lovin' it :P
Sl33py, when you say "it was the rack", what exactly did you replace???? the whole rack??
  • 3 weeks later...
  • 4 months later...
By rack, I mean the front steering rack had a slight bend in it (one of the arms I'm guessing?). It was straightened and also reconditioned and now everything is great.
Edited by sl33py
I can't believe that your mechanic couldn't find a simple problem like a worn tie-rod, especially if its been happening for over a year as they should check for play in the front end and rear when your rego inspection is carried out (NSW anyways) this should easily have been found and the business of changing every thing is poor dianostic work to say the least!
This is the reason you see people on A Current Affair crying about owning a lemon that has had XXX number of parts chnaged XXX times when in fact the company/workshop were just guessing what was wrong, throwing parts at the car without actually finding the cause of the real problem.
I'm glad your car is fixed mate but I'd find a new mechanic and name and shame all the places you got a wheel alignment done as they should also have discovered the problem as well.
Just my opinion.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
