My Car Is Wrecked! (warning - 5mb)
  • Replies 89
the other driver tried turning right off milton road into castlemain and obviously didnt see me... the result was a very nasty T-Bone and i am very thankful that he didn't have a passenger in his car.
Ive been down to the holding lot and it looks even worse than what it did at night...his especially
Thanks for all the support guys and ill keep you all posted
ah dam liam glad you were not hurt mate that suck :( good luck with the insurance Co, on another note I hope they right it off for you rather then fix it once a cars had a big hit like this its never the same....... (rattles, creaks etc etc & chassie are not built to take a hit like that)
As some one said above liam I would go down to the yard & pull any thing out of the car u can thats not listed on your insurance or u will lose it...
Woah, you're almost as skilful as I am, well atleast your ok, cars can be fix-crash and burnt, you'll be back on the road faster than you think.
Lok on the bright side, if it was writen off, you get o choose a new colour if you didn't like the white.
Good to see you are ok, I hope for your sake that they don't repair it.
The car will never be the same again. A write off might be a blessing in disguise. Let me know if you need any help finding another good one, I have contacts.
No offence, but from those photos I'd be saying you t-boned him - how did it happen?
yeh, but it was the guys fault as he turned right over liam's path when he should have given way...liam's light was green to go straight ahead
Must have been the night for accidents. Saw a newish Blue 200sx totally mauled on the corner of Webster and Gympie Rd near Chermside around 10pm. Looks like it ended up taking out what looked like 4-5 cars.
The most important thing is you guys are all ok. Hope insurance does the right thing by you.
yeah, that blue s15 was my car til i sold it to a mate of mine two weeks ago. i was in his car when it happened. luckily no one involved was hurt or anything.( i just cant walk properly atm coz my leg hurts). there were 4 cars involved and a lady ended up with being in the creek under the bridge.
yeah, thats what happens when an inexperience driver drives a turbo RWD car in the rain.lost traction and lost control of the car. totally write off.
luckily he wasnt doin anyting illegal, not speeding, no drinks, no one was hurt and he had a clean history. also, thanx to the ppl who gave their witness against what the cops accused us-- street racing and doin burn-out( how can u do a burn out in the rain that hard?) the only reason they came to that was it was close to aspley maccas and it was on thursday nite.
also, good luck to liam,mate. hope everyting goes well for u.
daym sorry to see that happen mate... hope all goes well with insurance.. as Erin said write everything doen etc.. im sure its a write off.. my old one was..good luck .. sad to see a liner like that..
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
