Just spent a week in Melb for training and while there I made use off one of your great assets there, Unique Coating Solutions, in Elata rd off Tullermarine Park Dr.
Had my centre console, dash suround and window switch panels in my R34 coated in a carbon fibre look paint, came up an absoulte treat!
He does some aweson effects out there and for a good price!
I can thouroughly reccomend him!
https://www.sau.com.au/forums/topic/94606-great-melbourne-asset/
dude, thanks for the pics, that shit is awesome!
now, can you tell me if thats just like a contact kind of deal, and stuck onto the plastic? or is it painted or what?
if he did ALL THAT stuff for $300, thats insane! the guy we were talkin to for the group buy was at like $350, + $50 to prep the plastic and that was with like 5-10 of us all buying at the same time!
did your guy do air con vents on the passenger side for $300 as well?
and i just realised he did your actual climate control unit as well!
Edited by dezz
It's not contact, it's like an ink sheet transfer, then sprayed with a two pak clear and baked in an oven.
Didn't do the vent's, I disassembled all the parts (removed switches, vents cig lighter & pulled air con panel apart) before I gave them to him.
I got a quote off a bloke in Sydney to get the carbon look done and he wanted nearly a $1000.00!!
I live in Tassie, so taken them over myself saved me a bit in frieght too.
since i work like 5 mins from this place it could come in handy for me...Can he paint the dash aswell, coz hte carbon fibre looks real nice, but i wanna get mine done in purple . Do you know if he does that aswell, if not ill go down tehre when i get my car back at the end of the week
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
