Just coming home from Rockingham about 15mins ago, up near Hepburn ave I noticed a car in the left emergency lane. Wow you must be thinking. Thought nothing of it because it wasn't a skyline :huh: , but I could see from the right hand lane it turned out to be none other than the infamous cockwad ROUSEY!!!! At this point I starting laughing my head off, I almost had to stop I was laughing so bad remembering his bs on the forums.
I was so tempted to turn back around, pull over & just give him shit, but I thought of that too late. His car looks shit by the way.
Maybe you had to be there, but it was like seeing something that you weren't 100% sure to be real, but then you see it yourself.
:O
https://www.sau.com.au/forums/topic/94655-pmsl-everywhere/
wyhoa re you tlakjoing about? fulkl ofg bs somehsone said? ghost turbo.'/? i dont undertsandt man explain eyn
spot the drunk dude who decided it'd be clever to get on the net while sobering
AAAAAAAAHAHAHAHAHAHA ROFL ROFL ROFL ROFL ROFL!!!!!! :lol: :lol:
https://www.sau.com.au/forums/topic/94655-pmsl-everywhere/#findComment-1709318
my favourite is when he pretends to be a driver of a quick GSR and starts worshipping himself. But then the moderators picked up on the fact it was the same IP adress. rofl nothing quite like a wanker sucking his own cock. I mean he thinks ppl hassle hime coz he doesnt drive a skyline. Hello! I drive a charade! People dont hassle me coz i dont claim its quadruple turbo, NOS kit, V8 rotary that uses a RB26 as a starter motor (I took that engine out coz it was too slow).
<--- also note my Pro Rousy propaganda
https://www.sau.com.au/forums/topic/94655-pmsl-everywhere/#findComment-1721114
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
