  • Replies 131
Just got this.
Auto-Motion Australia
Ph/Fax: 02 48 722-622
AUTO - MOTION AUSTRALIA
Hi Drivers,
Our final two events are happening during December.
FRIDAY DECEMBER 9: SKID PAN SLIDE CONTROL - EASTERN CREEK 9AM - 1PM, $110.00 4 positions. left on this course.
FRIDAY DECEMBER 9: SKID PAN SLIDE CONTROL - EASTERN CREEK 5PM - 9PM TWIGHLIGHT SESSION
FRIDAY DECEMBER 16: SKID PAN SLIDE CONTROL - EASTERN CREEK 5PM - 9PM TWIGHLIGHT SESSION
Twighlight courses are $135.00
We have positions available for both twighlight courses, they are filling though so if you are thinking of joining us, please act fast as we will not be allowing large groups on the twighlight courses.
Cheers all
Aaron
Mob: 0410 317 013
www.auto-motion.com.au
www.aaronmcgillmotorsport.com
Turning dreamers into drivers.
AM_Event_Booking_Form_.pdf
the skid pan was great. GTR in RWD on the wet pan is good wholesome fun! I remained undefeated in the tandem challenge untill the last run of the day when i threw it in the bin trying to be a show off! oh well, for the guys going tonight have fun :D
  • 1 month later...
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
