  • Replies 199
^^^^ SHOW OFF!!! :)
Sorry peeps but I'll have to be removed from the list, I will be on holiday from the 8th & my car will be getting raped & pillaged, but I will definately be up for a later date.
bump,
hey guyz,
so whats the deal, do we have enough ppl for our own lane yet? or should we starting inviting externally of SAUWA? i have a mate who isnt really part of any club who owns a MR2 that might be interested...but do we want to do that, or just keep it to da sexy skylines?
Thanks
Hopefully we'll have enough people by that date. I've booked the lane already. They are welcome to come down on the night though and race... if we do need the numbers on the night they can say they are with SAUWA. I'll let you know closer to the date
Regards,
Dan
If you get stuck for a last person then let me know, I will join up (with SAU) and make number 20 for you.
Car has a boost leak so hopefully once that has been taken care of I will be able to do a better time. It would also explain the overfuelling....I thought it had one ages ago, but dismissed it as me being paranoid! Haha. 2 weeks notice would be good, if I can help you out just let me know.
G'day everyone, have you got room for one more?
went to the drags tonight for the first time. . . would be keen on going again, i'm not a paying menber for SAUWA yet but I'm looking to join . . .
I have a 14.6 to work on :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
