Don't know if anyone else is experiencing the following but I've noticed that while using OE100, during days where the ambient temperature is above 28C, I get erratic idle ( hunting and popping ) once at operating temp. Otherwise it drives well. ( on 2nd tank of OE100 ). Got to fill up today so I'm going back to Optimax 98 to see if anything changes.
  • 1 month later...
  • Replies 168
http://www.racefuels.com.au/dynoDetail.asp?ID=59
Interesting read. (Sorry if it has been linked already somewhere)
Tests on an Integra Type R 1.8L showed :
Ultimate 98 - 135rwkw
Optimax - 133rwkw
Optimax Extreme - 139rwkw
Elf race fuel - 140rwkw
"Assuming that a fuel has reasonable octane ratings (say min 98 RON) then the lighter the fuel (density) the greater the performance. Ethanol is quite a dense petroleum product and is unlikely to greatly improve performance, in fact in all our testing in adding 5% and 10% ethanol to all the fuels tested we saw no performance increase, if anything it acted as a detonation masking agent"
Edited by Beeble
as this fuel was covered in HPI i believe it was. I think they gained about 30kw + in a skyline running e10
The whole car was retuned with the ignition timing getting some serious cranking. The car gained 30kw from e10 and a tune. I'd say if you live near servos that have it, get it tuned on it, it's great stuff.
"Shell Optimax Extreme is a new super-high octane fuel with a minimum octane rating of 100, the highest currently available at any Australian service station. Shell Optimax Extreme is formulated with 5% ethanol."
*cough* I think you'll find it is E5, if you care to read the article closely.
They used pump Optimax Extreme in this particular test, not Boost98 or E10.
Correct me if i'm wrong....
edit:
\/ \/ btw Kimbod i'm not advocating the use of this stuff, just reporting on what i found. I'll be sticking to "normal" 98RON and getting my car tuned as such.
I don't recall ever saying "lighter = more power". I have a basic undertanding of the priciples of combustion :D mleh.
And yes, i agree with what you're saying.
Edited by Beeble
I would be very surprised if anybody can tell the difference between 98 ron and 100ron on any given day.No two days have the same temps and also barimatric pressures.Research Octane Number is a fuels resistance to knocking and pinging. Motor Octane Number is a fuel"s drivability. It is a lower number than RON.Oil companies have agreed with the Fed Govt to increase the use of ethanol. Manildra is the main supplier of this . It is a byproduct of their wheat processing for the food industry.Mind you any fuel with ethanol should be cheaper to buy as it cost way less to produce and hasn't got the taxes and duties that crude oil has.The car companies don't want more than 10% because with the standard ecu this is all that they can guarentee won't hurt the motor or fuel systems. Ethanol tends to promote the absorbtion of water in the tank. this cause problems in lines and injectors.Nissan's with their ecu and sensors will adjust for the different fuel's rons.
A denser fuels gives more power , that's why Shell advertise it that way, but being denser tends to slightly richen up the mixture.Sorry Beeble lighter is not more power.Most of the threads here are too simplistic. Crude and it's distillation and the production of Gasoline is extremely complex We don't just use 1 crude at a time it is always a mixture of up to 5-6 different crudes so we can get different specs for Jet Fuel , Diesel ,etc. Also availability and what time of the year it is as specs change in summer and winter.Our dyno testing is carried out in climate contolled laboratory. The oil companies have special licences for all these specs. If We put out to market fuel that doesn't meet fed govt specs we would be in the shit.Shell extreme is basically as said here. 98 ron with 5% ethanol. I think you will find most companies will follow this soon. Also this helps boost ron with the removal of Benzene from 01/06
Edited by kimbod
If you check out the website I am sure it will answer any questions you have of Optimax Extreme.
www.100octane.com.au
Brief recap.....
It is a 5% ethanol based fuel (not 10%)
Ethanol is a natural product derived from sugar cane.
The small amount of ethanol will not hurt or dammage any part of your cars fuel system anymore than normal fuel does already.
Ethanol is an oxigen rich fuel around 30%
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
