Don't Take Your Mum's New Camry To The Track.
hmm so his mistake was that he downshifted at high speeds around a bend?? Or the fact he went to fast into the corner? hmm ..
it's a combination, he got to the corner too fast and was then lifted off the throttle mid corner to down shift which generated a fair whack of lift off oversteer, he tries to correct a little but at that point seems to be hard on the brakes which in the massive slide he is now in means he has no traction to alter the cars angle and bascially just slides into the pond. :P
  • Replies 51
lol handbrake is gold, i just realised that if this vid matches that outside shot (it must!) then this qualifies for WELCOME TO LAST YEAR
Yeah it's defintely an old video :P
99% of SAUers would do exactly the same thing, or worse, as they have 100 more hp at their disposal and probably less talent. :)
Bit rich to sit back and bash the guy with your keyboards.
After he lost it he did the right thing...on the brakes!
I reckon good on him for having a go and not just modding his car with bullshit bling and acting like you are the long lost love child of fitty cent and paul walker...
who care its a gold video
wish i had one of when i nailled the wall at the track
all that money wasted and nothing to show for it
just ask duncan he has it on video
if i did i would have a small tv dedicated to playing it over and over again!!!!!!!!!!!
haha ill see if I can dig up the video...got in my hdd somewhere...
its a guy named russell going around wakefield in his red wrx..and some hillarious commentary to boot...
I'm holding out to see it!
Impressive.
I would have thought a badly-done downshift would have compression locked the front, causing that to wash out instead.
But at the same time unbalancing the car mid corner, big no no... heal and toe!!! :P
Here's the thread - unfortunately it doesn't look like the vid is still up  :(
What about the brakes Russ?
Starts around post #34.
Did anyone save a copy?
yeah I saved a copy......but I dont know how to upload videos on to this forum.... :(
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
