Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
  • Replies 520
the gtr seems to be a more refined product with proper mounting points and radiused edges. is that the finished item for the gtst?? so the only mounting points are the 2 centre drillholes in the pic?
cheers.
Hi Pete,
Just had another look at my grille and was wondering if there was a different one for the Series 2 R33?
Here's a dodgy snap of mine. You can see that this is different to Ruffel's grille as this one has no top edge bit. If that radiator guide were to be used here, I'd think it would look a bit funny as it doesn't finish on an edge.
Edited by lordsnipe
Hey guys.
The GTS-T guide will be modified before cutting to have the radiused edges and all that, and I'll make sure to post 3D images of it before I do.
The R34 GTT guide mounts through only two holes which also hold the bonnet latch.
The R33 GTR guides require a fair bit of work to get on and off as several bits have to be removed to go through the holes and slots.
Whereas, the R33 GTS-T has cut outs for these bits.
I was actually going to remove the holts and slots and make cut outs in the R33 GTR, but thought I'd just leave it as it is and you can cut the holes out easily yourself if you wanna make it easier to get on and off.
I will have a look at extending the GTS-T guide a little but not sure whether it will work on both S1 and S2 cars.
But with those pics you get a better idea of how it looks and sits.
Lordsnipe.
I checked the R33 GTS-T guide on several cars at the BBQ and it fit all of them, even those with custom bars, so you shouldn't have a problem.
CHEERS
BASS OUT
quite sure.
you can read back in this thread and its been answered...the guide attaches to the front of the support, whereas the snorkel sits on top of the support and isn't restricted what so ever.
My account details are below.
Peter N Blythe
Bank of Melbourne / Westpac
BSB: 733382
ACC: 586817
Amount $100
Transaction detail: Guide - 'username'
So the word guide and your username, or as much of it as you can fit.
So far only 5 people have paid......
Hey Nate.
don't worry, I haven't forgotten about you.
Gotta finish these grouop buy before I'm going to have a chance to make yours, but I will get there!
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
