Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Okay.
Just gave the guys next door a slab of Carlton Draught to fix up the R33 GTS-T guides.
SO. All of everything is now done.
Unfortunately I have to be on a plane at 6:10am tomorrow morning to go to Newcastle for a day, so I wont be able to get any out tomorrow.
I will take the anoising guides to the Anodisers on Thursday and I should have them back early next week.
I will get some guides out this week, and some out next week.
I'm happy that they are all now finished!!!!
I'll let you know who's had gone as they go.
BASS OUT
  • Replies 520
I hope your being sarcastic.
Cos i know i'm pissed that he is taking the time to do this for us with next to no profit as far as i know. You could always buy one of these from eastbear i think for about 300 bucks, OR you could shutup and deal with it.
its a big responsibility for him to organise this for so many ppl, so i appreciate it very much, i know i oculdnt be bothered to do somethin on such a large scale hehe
ben...
Okay,
What the air guide does is stops the air from going through your grill and up over the top of your radiator.
It forces air through the radiator and increases the cooling capacity of your radiator.
Also, it looks cool and gives you somewhere to put stickers.
is this an gtr ?
Dudes,
I just had a HOOOGE win.
One of the rollformed profiles we are working on at work is the perfect size for the protection of your guides during transport!
I was thinking that I was going to need to cut and bend up a shitload of sheetmetal myself to pack them for shipping, but as luck would have it, I now don't need to.
What was going to take me about 6 hours will now take me about 2
TOPS
I reckon I could have most of them shipped tomorrow morning!
BASS OUT
Thanks again for your patience, you have all been very understanding.
okay.
a whole bunch of guides are packed and wrapped.
I have to finish them tonight.
I've taken the Anodising ones to the Anodisers, they should be back by Friday.
All the R33 GTS-T guides that aren't anodised will be taken to Aust Post tonight or tomorrow.
The R33 GTR guide will go to the sole owner with this lot also.
The R34 GTT guides I should be able to get them out tomorrow too.
The Anodising guys, your's will leave next week.
the Melbourne guys, I will bring them to the Meeting next week.
Done, Done and Done.
The following people should keep an eye on their mail box in the next few days.....
2BNVS
GTS-T V-Spec
ZXFIRE
wolverine
Lordsnipe
Alpine Stars
bilbo117
Sydneykid
Trick
Cooper
YEEEE HA!
PS. Each person gets free with their purchase, a section of Metal Fascic for your house. Although the bits are in various states of tune. I wouldn't try to fit them to your house!
The rest of you who have paid, and are not on this list, you either are waiting for Anodising, or you have something other than an R33.
The R34 guides are going to be packed tonight.
Somehow.
or didnt pay for delivery and have to pick it up :rofl:
Hopefully i'll get to the meeting to grab it off you, otherwise ill grab it at DECA
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
