if its manual, in good nick, i rekin you could start your asking price over $20k, as many do on carsales....
and be prepared to drop a bit....but if its good condition, and maybe has some mods you can probably get around the $19-$20k mark
https://www.sau.com.au/forums/topic/95770-skyline-prices/#findComment-1733323
Assuming it is standard and in fair/good condition, based on the ones I looked at. I would put it around the 17K mark and probably drop to 16K at the lowest. There are lots around the 20K mark but they dont seem to be selling IMO.
https://www.sau.com.au/forums/topic/95770-skyline-prices/#findComment-1733846
over 20k for a stock line?
ROFL... ease up
a) we dont know that its stock
B) its a series 2, and a lot of series 1's are selling at $15-$17k.
and c) you dont set your asking price at what you hope to get for it. you always add more on so that there is room to move
https://www.sau.com.au/forums/topic/95770-skyline-prices/#findComment-1733866
no point adding 4k onto the asking price now is there?
there is no "set" rule that says you have to add $$$ onto it.
Your much more likely to have a lot more people enquire if the price is cheaper etc so your only cutting yourself outta the market if you add say, 4k onto the price as everyone will look and not even bother
https://www.sau.com.au/forums/topic/95770-skyline-prices/#findComment-1733986
yeah $4k is a bit rich...but i think you should at least ask a little bit more than what you're willing to accept, just so that when you get the bargainers coming, you do have room to move, and they think they are getting it cheaper than what u wanted to sell for.
but we know basically nothing about this guys car, no mods, no condition details etc...its shooting blind
https://www.sau.com.au/forums/topic/95770-skyline-prices/#findComment-1734106
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
