Group Buy: Cb Radios (updated - Dec 23)
ey ni, good work on the price of the units + charger.
i cant get to the christmas BBQ thing coz ill be working, so how much you rekin its gonna cost to post it to me?
and i can just direct deposit the cash into your account :wacko:
  • Replies 255
unfortunately it is... but if you find someone else you can go halves in a pair on ebay from the same shop... wont be quite as cheap but not far off.... should be able to pick a pair up for 90 delivered or less.
ok... silva33 you might be ok.
EVERYONE listed please email me [email protected]
Give me these details in the email:
First name:
Last name:
Forum Name:
Address:
Contact Number:
Pickup or Postage:
Im creating a XLS so i know who got what and if they want it shipped or pick it up from a meeting/my joint.
I'll send out a mass email confirming the details and costs etc.
LATEST UPDATE!!ALRIGHTY! 567.5 Delivered to my door for 14 units! Thats $40.60 per unit + $6.05 for the charger (mains) so a total of $46.65. i think the easiest way to do it would be to transfer say $26.65 for now and the rest when ya get it off me or you can do it all at once if it suits you. So if someone wants to organise the buy of all the other bits like batteries and stuff that would be good.
UPDATE:: 12 chargers (mains) have been purchased at a cost of $6.05 each. This will be added on to the total once i have bought all the handsets as well. Total cost should be up by monday latest.
Ok so so far we are only going to be buying the mains chargers and main units off these guys from ebay. The rest of the accessories can either be bought from Jaycar.
Alright Nark, you want me to come around with the dosh? Or we can meet up for a coffee too :O. Actually everyone of us should meet up at a cafe somewhere this end of week or weekend!!!! To collect the goods and talk shit lol.
Email me [email protected] or my direct line 95527273.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
