Boof Heads.
How about you all jump in and race in a class, any class, JUST PICK ONE and support this sport by filling fields and racing instead of whinging that the Sport Compact classes are to difficult to race in for your particular ride.
There's a class for just about everyone that falls even vaguely under the S.Compact banner. Get over your petty grievances until you can actually say that you are supporting the future of this sport.
Adrian
  • Replies 46
Dude you're a goose, there are a few ways to look at that ruling. One is that the cars are meant to be "street" cars, and should be running stock gearboxes. Another is by restricting the transmissions allowed will encourage cheaper parts.
The reality is that the only OEM parts used by the majority of the qualifying field is the outside case. So a $10,000 PPG box is "worse" than a $4,000 Powerglide? From a breakage point of view too the Powerglide will be cheaper to run and maintain than a dog box. How is that a realistic rule?
They way I look at is from a performance perspective, not a cost one. I don't think you can write rules that stop people spending money, they will spend whatever they can afford.
The rule writers are obviously of the opinion that the ability to change to a non OEM gearbox is a performance increaser, that's why they handed out a handicap for doing it. My view is that an high stall speed drag auto is worth more than 150lbs in performance, I chose 200lbs based on the weight/performance index.
I am simply saying that 150 lbs is not enough and that 200 lbs is a more accurate reflection, I don't think you should be attacking me on the basis that they don't need a handicap at all. That is already decided and agreed and included in the current regs. If you want to argue cost (which I think is a valid argument by the way) then you need to do just that.
I should emphasise that I am not asking to run a LIGHTWEIGHT R32GTST, all I am asking is to run a STANDARD WEIGHT R32GTST . So I don't think is is either fair or accurate to tell someone with a standard R32GTST to go and race in another class. Because that's what the current regs say.
:P cheers :)
Edited by Sydneykid
:P cheers :)
Sorry Gary but you say your R32 weighs 1180 kgs with roll cage +driver weight but the stock specs for a standard R32 seem to be 1320kg with no cage +driverhttp://imports.motortraders.net/imports/spec.asp?id=668 but you've only made minimal weight reductions and added weight by adding a cage hahaha
So really a STANDARD WEIGHT R32GTST will have no problems at all racing in SRWD class
I have no idea where they get 1320kgs from, but it isn't correct.
I have the Japan exit weight for mine and it was 1265 kgs, that's a standard 1990 model R32GTST M Spec 2 door with aircon. It had no ABS or sunroof and a little fuel in the tank (not much).
This is an extract by funkymonkey on R32 specs
http://www.skylinesaustralia.com/forums/in...9&hl=definitive
As you can see it quotes 1260 kgs, so mine is no super lightweight. Add an 85 kg driver and you are at 1345 kgs, that means 64 kgs of lead to be added to a stock standard R32GTST.
:) cheers :unsure:
Boof Heads.
Adrian
WORD
sport rwd had 98 entires at qld jambo about triple that of sport mod.
exactly the top guys in sport rwd should be advancing into sport mod.
especially when most of those cars fit sports mod rules a whole lot better then sport-rwd....
mick
they have to run slicks to be in sport mod, you cant run street tyres in sport mod.
i dont think the top cars want to run against kier wilson or the 7 sec rx3 from PAC.
mick
Its DYO so i don't know where the fear comes into it...i think the word thrill comes to mind more than fear.....Anyway....who is Kier Wilson ?
yeah isnt it a stock rb26 doing 8s?
lol
that'll show those 'stock' 2js
ahh yes....i do remember reading about that car in a mag.....an engineering marvel
why?
what motors would you like to include?
remembering we are sports compact. its not about big engine displacement?
mick
VQ45 Nissan engine is what he wants included.
Does anybody have a rule change suggestion that doesn't directly influence their race car??
Ahh yes there is one person....see second post.
VQ45 isn't eligible right now - due to the maximum 4.1L displacement rule. Any thoughts on the maximum discplacement rule?
V8's are not currently eligible to run in Sport Compact either. I am open to arguments for and against though. I am yet to be convinced one way or the other as to whether hi-tech, late model injected OHC bent eights should be allowed to run or not.
Adrian
I think it should be the same as the NHRA Sport Compact at 3.5 litres maximum limit.
it will always be dyo,
dyo is harder racing than head up any way, you have to think about it way more.
DYO is all about preventing racing becoming too expensive for most to compete.
DYO can have it's own moments of excitement, but there's something intrinsically wrong with sandbagging, buttoning off and braking during a drag race.
I think it's a good concept but it can have awkward moments, especially during the infancy of Sport Compact where field sizes are so low. You can get really embarassing ETs for class winners which does not provide excitement for the spectators.
In my experience 99% of spectators do not understand DYO or the handicap starts. If they were better educated they might understand some of the excitement as the quicker car tries to hunt down his competitor and all the drama about should I or shouldn't I at the top end.
Even fewer understand index classes, but then there are none in Sport Compact at the moment.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
