hey guys
i want to replace my standard turbo on my rb20 but i want one that spools up pretty early. i know most people go for big turbos for big power. i just one that will be very responsive. is that unrealistic or is lag the nature of turbos.? ;)
https://www.sau.com.au/forums/topic/96297-which-turbo-for-rb20det/
it is standard apart from boost controller, turbo back exhaust. i have heard power fc will make it more responsive backed up with a bigger fuel pump and injectors. intercooling ive heard helps too? as far as the exhaust housing goes i havent a clue which is proper or not is there any way i can tell without taking off the turbo?
Two good turbos that will get you a good amount more power with out affecting response too much are:
RB25 turbo (non-neo because they are weak turbos using epoxy plastics for the compressor wheel which are known to fly apart when pushed).
VG30 roller bearing turbo which are a bit rare to find in good condition.
They are both ceramic exh. wheeled which plays a big part in quick spooling up times.
Steel exh. wheels are heavier and take more time to get spooling escpecially when the wheels are bigger, inturn creating more lag.
It all depends what you want at the end of the day really
response over power or
power over response
a remap will give you a good comprimise. do you have a fmci or the standard intercooler still ? larger injectors wont help the spool up or fuel pump, as long as you aren't leaning out of course.
the VG30 turbo are LAGGY for Rb20, do a search
RB25 turbo is a good budget upgrade
HKS GT2510 / 2530 will be my pick for around $1500
remeber to prepare a budget for the support gear (fuel, cooling) and tuning
Edited by Maxx
VG30's are in no way laggy on an RB20 id know coz im running one. Making 180rwkw with boost from 2500-redline. Great little ball bearing turbo. But im in the same boat and wanting more. Apparantly TD05-16G's or 18G's are the way to go for a fair amount of power to lag ratio. 230-260rwkw with good response (Kelly McKinnon runs one). And the HKS 25-30's are a good mix with minimal lag for power giving around 230 as well.
VG30DET BB turbo's are indeed laggy POS.
I've had one on my rb20det, it made 1bar a shade over 4000rpm under general driving conditions, first gear was quite sloooooow and lazy. I pulled it off and put back on the stock turbo and pushed boost up to 1bar, the stock turbo has a much fatter mid range, sure it won't pull hard to 7500rpm but it did pull hard to 7000rpm with a good ebc so that the little turbo will hold boost. Holding boost is the key to having good top end with the rb20det turbo.
The VG30DET BB turbo is simply a glorified RB20DET turbo.. It runs the exact same compressor and turbine wheel as the rb20det.
So in thoery and practice you can grab a rb20det turbo, drop on the vg30det comp cover and turbine housing and whamo you have a vg30det turbo.
Put it this way... Rb25DET turbo R32 vs VG30DET turbo R32..
The RB25DET turbo R32 will rip the Vg30det's a new bum hole, much more mid range.
The R34 turbo runs the larger vg30det turbo turbine housing.
The R34 turbo is the pick of the bunch and will make more power than all of the other turbo's under it.
The Vg30DET turbo can be considered as favouring exhaust flow, not what a little 2ltr needs. Sure it works really well on a 3ltr and drops the power band in just the right spot but on a 2ltr it is slow.
PEAK POWER IS NOT EVERYTHING. :)
no FMIC at this stage, just standard. speaking of intercoolers that is next on my list, i have seen ones from $700 to about $1800. the cheap ones drop alot of boost about 5-8psi( so i have been told) and the internal fins are chunky(inefficient). i went to ASE and saw one with micro fins and no big blocked sections in the core. i was told a boost drop of 2-3psi would be expected and alot more cooling than the cheaper alternative. it is alot of money to fork out, is it realy worth it? i am not planning on making mega hosepower anyway. there is a hybrid kit r32/r33 at autoban for about $600 and it is a decent size looking unit. feedback???? <_<
I've been in a R32 GT2510, R32 with a RB25 turbo and my own R32 when it was running a VG30 turbo.
The RB25 turbo spooled a little quicker and felt as if it came on smoother than the GT2510.
The GT2510 went well and went hard once on boost.
The VG30 turbo sucked compared to the others.
Edited by Cubes
Dude ive been drifting my VG30 and ive got nothing but praise for the little unit - i think the sppol up is great and not too laggy at all, but i might get either a fuel cut and reg and get a 2530 or i might fork out and grab a powerfc and larger injectors with a 2530 - unless i can manage to find an R34 turbo - but im hell happy with VG30 its got great response and is wicked for drift on 1bar
I do hate the VG30DET turbo on a 2ltr.. On a 3ltr it works nice.
The 2ltr simply does not need the larger turbine housing when paired up with the small compressor wheel it runs, sure it works but it produces the same lag as what a GT2530 or GT2510 produces yet it doesn't deliver the goods.
The larger turbine is required on the larger motor as you don't want peak power being made at 4000rpm. :O
Drop a RB25DET turbo on Nathan and you will drift better. :O
Edited by Cubes
Get a Garrett GT17.
/Thread
wasnt the GT17 off a SAAB. i read somewhere they are pretty small, and not much of
an upgrade and can only run on low boost. i think i will consider the 2530 see if i can
pick one up cheap 2nd somewhere. ive only heard good things about it. thanks guys :O
i was down Asian Autospares (just near Moss st) and he had an rb25neo turbine there. he wanted $750 for it (without water/oil lines, but he says i can use the rb20 ones?). i thought thats a bit expensive, but, whats your opinion? it actually looked rather bigger then th rb20 turbos he had down there..
shaun.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
