Did you call it 4 Square or Downball?
73 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Back in the days of your primary school / high school / secondary collage did you refer the game as Downball or 4 Square? The game I am talking of was played with generally 4 players (but not limited to) and the playes were given titles of King, Queen, Jack and Dunce. The object of the game was to hit a tennis ball and to get the other players "out".
What did you call it? To me it was known as Downball, others believe 4 square
https://www.sau.com.au/forums/topic/96894-downball-or-4-square/
  • Replies 43
I'm with the Snowcone!! Downball is against the wall you MONKEHS!!!
4 square is the one with the King, Queen (which led later on to a social complex), Jack and Dunce.
As Bec also stated, this carried on until it was some ridiculous number like 16 where you ended up having to lob the ball over everyone's head to make it fun.
Loved the backhanded shot to fool the person behind you.
SAU 4 Square and Downball Championship series!!!
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
